Hey guys-
Quick question on something I just can't seem to figure out. In my skin's settings window I have made a place to change a system image. When you click on the image, a custom Select dialog pops up and you then select a new image from the list. When the dialog closes however, the image doesn't change to the new one until I close the skin settings window and reenter. Is there a way to force the refresh of this image?
Any help would be greatly appreciated.
~ Zexis
I shall assume from the lack of response that this isn't currently possible...
No it should work, don't know why it doesn't for you. If you have e.g. this
PHP Code:
<control type="image">
<texture background="true">$INFO[Skin.String(CustomImage.Path)]</texture>
</control>
and you change the string to a new image path, image should change immediately.
Hrm... maybe I oversimplified. Basically I am give user the ability to Pin a tile in my skin. ie- Selecting the Favourites tile sets the Skin.String 'Tile1' to the value 'Favourites'. I then have intelligence in the skin that sees the value of "Favourites" and includes "Tile_Favourites" in the Tile socket.
<include condition="Skin.String(Tile1,Favourites)">Tile_Favourites</include>
Tile_Favorites is defined in the include files as the tile icon image.
For some reason this is what doesn't load.
That said, I also have the following text which seems to work fine without reloading the screen-
<onclick condition="Skin.String(Tile1,Favourites)">ActivateWindow(Favourites)</onclick>
Skin.String(Tile1,Favourites) is an invalid command. What you want is stringcompare(Skin.String(Tile1),Favourites). You should also know that includes are only reviewed on WindowOpen, so you need to do a skin reload or leave and re-enter the window. You need to include Tile_Favourites without a condition and show/hide it based on a visible condition.
Ah, so the include is the problem... thanks.
Regarding the Skin.String(Tile1,Favourites) being invalid- that is very interesting, because it actually works.
Try setting Tile1 to something else than
Favourites. I bet the condition is still true.
Edit: Really seems to work. Another thing which is not documented in the wiki.
Edit2: Added it to the wiki.
(2013-06-26, 23:23)`Black Wrote: [ -> ]Try setting Tile1 to something else than Favourites. I bet the condition is still true.
Glad I could contribute!
