Full Version: Suggestion for the XBMC Media center (Aeon Nox)
After you use the xbmc media center, complete it in Yes remains the best and easiest set up currently, tried for several times to use the media portal, but in part to customize the button and create your session the xbmc media center is about the best option with the Nox Aeon theme.
But it still has a basic problem with the DB movie data and video clips, I'm from Brazil and our title here is totally different.
I think you should put an option in the system so that we can leave the original title that is written to the file, example (My filme.mk) (Appear so my movie) movies and video clips.
Also an option for movies and video clips between the correct session even if you cannot pull the info from the DB (database with the detail of the movie or video clip).
With this two detail the system will be perfect, any doubts I can from an example in video, and I'm sorry for the bad picture even as English is not my language.
Huh
