2013-09-02, 16:20
2013-09-03, 14:46
ProjectM is compatible with Milkdrop 2 presets, would it be easier? I see they have XBMC on their homepage. I use Windows, maybe it's already implemented for other versions?
2013-09-10, 11:32
Yes the very latest ProjectM 2.x code from http://projectm.sourceforge.net should build for both OpenGL 1.x and OpenGL ES 2.0 on all platforms so a port should work
projectM latest code with OpenGL ES 2.0 support should even add the possibility of iOS and Android support too, as well as Linux and Mac OS X
I am sure that just as many Apple TV 2 and Pivos Android users as well as Raspberry Pi users would appreciate projectM visualizer on their platforms
There are already other existing feature request for this too, like http://forum.xbmc.org/showthread.php?tid=171519
2013-09-11, 21:20
Please devs! +1
Go for it! Support on rPI would be awsome!
Cheers Nordish
Cheers Nordish
2013-09-11, 23:08
https://github.com/cptspiff/visualization.projectm uses 2.0. i haven't tested fancy presets but it's 2.0
2013-09-11, 23:20
Hey spiff is that something we can replace the current visualisation with? Where do we need to put it to get it to work?
2013-09-11, 23:27
disclaimer: you know what to do with the git or you don't.
2013-09-11, 23:30
Ah you big meany! no worries I know how to download it just not sure where the visualisation stuff goes but I'm sure I can find it
2013-09-11, 23:34
And you need to compile it too.
2013-09-13, 02:49
Ah
2013-09-13, 11:48
(2013-09-11, 23:08)spiff Wrote: [ -> ]https://github.com/cptspiff/visualization.projectm uses 2.0. i haven't tested fancy presets but it's 2.0Great work! Please note that upstream have released ProjectM version 2.1 now as well
ProjectM 2.1.0 was actually released over a year ago now
http://sourceforge.net/projects/projectm/files/
Thank you very much for looking at it! Hoping to see a OpenGL ES version for XBMC soon too
2013-09-15, 20:06
linux builds are here: https://launchpad.net/~wsnipex/+archive/...s-unstable
note that you will get an error that the package tries to overwrite stuff in the xbmc package, so you must force install it for now.
2013-09-21, 17:08
Can someone please help. I tried disabling it and now it still plays screensaver trailers. I have since uninstalled it from the add on itself and it's still playing screen saver trailers. Looked in the user data folder but couldn't find anything. How do I get it to stop?
2013-09-30, 11:47
did this ever get tested on the OUYA platform? even if it is buggy would be nice to see further development.
not sure i remember how to install these on my OUYA.
2013-11-14, 00:51
(2013-09-30, 11:47)ktjensen Wrote: [ -> ]did this ever get tested on the OUYA platform? even if it is buggy would be nice to see further development.
I would also like to know how to install on the OUYA.
