Full Version: Nexus 7
First post but have lurked for a while, I'm sure someone will be able to help.
I have just gotten a Nexus7 and have installed XBMC on to it. Running Aeon Nox as a skin. I want to change some of the artwork, logo's and so on. I would normally just press "I" and this would let me do this.
Is there any sort of on-screen K/Board I can use for this as I don't have an external one that I can use. There is no problems with streaming and everything appears to play fine.
Thanks in advance Smile
Does your remote let you bring up the contextual menu? If so, "Info" is an option there.
I believe it's a two finger tap on the highlighted file to bring up context menu then you should see the movie info and the extras.
err, doh, don't know how I missed that this was on a Nexus 7. Yes, two finger tap or one long hold will bring up the context menu.
Thanks will give this a try
