2013-06-03, 15:21
Is there anyone using the G-Box Midnight MX2 that can answer the following two questions.
1. How does it perform with live rtsp:// streams?
2. Can you leave it connected to an rtsp:// stream for long periods of time while you are using the TV for another function and then switch to the HDMI port it is using with the TV remote and have it display the stream?
I want it to continuously monitor an IP camera and be able to switch to its feed if an alarm sounds. I do not want to find that it has stopped working because the feed was not being actively used for an extended period of time and then have to go through a reconnection process.
