Full Version: Odd FanArt disappear & re-appear issue
Hello I have only been using EMM for a short while but I am noticing some strange things since I have. First off the program overall seems to be just what the Doctor ordered does what I want but I've noticed that when I go to watch the movie I've chosen all the posters the fanart & info are all there but if I stop the movie or the movie ends & it returns to library the fan art is gone and just seems to be FanArt doin this. I can fix this by doing a simple refresh of the movie or backing to the menu sometimes fixes it all of the images are in the folder as they should be in the folders with movie & the nfo created by EMM this happens in any skin I use & also happens in any view.
I am running XBMC from a Window PC & have the latest version of Frodo with Confluence skin any help would be great! Thanks in advance!
I think this is a XBMC problem. I have partially the fault itself since 12.2. Do you use a MySQL database into XBMC?
(2013-06-07, 13:58)DanCooper Wrote: [ -> ]I think this is a XBMC problem. I have partially the fault itself since 12.2. Do you use a MySQL database into XBMC?
Yes & thanks for the response. It seems to come & go for me maybe a memory issue not sure.
