2005-12-07, 07:06
hello,
i have 2 xboxs. on one xbox i can see the current weather icon and temp. on the main screen (button left hand corner) while the other xbox is not displaying it. i can not find any setting where this feature can be enabled.
there is no network problem, if i go inside the weather menu this works on both xboxes. i can see rss feed on main screen as well.
they are both running exactly the same version of xbmc. have tried deleting the xbmc udata and tdata. deleted the entire xbmc folder and reinstalled the it, but still no go.
it's only the main screen not displaying the current weather icon/temp on one xbox.
can you please help. thanks.
