2013-07-13, 02:21
Really excited about this, but it is just repeating the first song over and over. Skipping to the next track only takes me to the beginning of the same song. So close!
12:47:46 T:3041447936 ERROR: Texture manager unable to load file: /home/pi/temp/plugin.audio.songza-1.0.0.zip/icon.png
12:47:48 T:2835346496 NOTICE: Thread Background Loader start, auto delete: false
12:48:00 T:3041447936 NOTICE: Previous line repeats 3 times.
12:48:00 T:3041447936 ERROR: Control 50 in window 10501 has been asked to focus, but it can't
12:48:03 T:2835346496 NOTICE: Thread Background Loader start, auto delete: false
12:48:07 T:2835346496 NOTICE: Thread XBPyThread start, auto delete: false
12:48:08 T:2835346496 NOTICE: -->Python Interpreter Initialized<--
12:48:14 T:2712056896 NOTICE: Thread Background Loader start, auto delete: false
12:48:18 T:2835346496 NOTICE: Thread XBPyThread start, auto delete: false
12:48:18 T:2835346496 NOTICE: -->Python Interpreter Initialized<--
12:48:24 T:2835346496 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: No JSON object could be decoded
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 346, in <module>
(mode['handler']() for mode in MODES if mode['id'] == args['mode'][0]).next()
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 346, in <genexpr>
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 171, in ListScenarios
data = GetData(url, params)
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 51, in GetData
data = response.json()
File "/home/pi/.xbmc/addons/plugin.audio.songza/resources/lib/requests/models.py", line 625, in json
return json.loads(self.text or self.content, **kwargs)
File "/opt/xbmc-bcm/xbmc-bin/share/xbmc/addons/script.module.simplejson/lib/simplejson/__init__.py", line 307, in loads
return _default_decoder.decode(s)
File "/opt/xbmc-bcm/xbmc-bin/share/xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 335, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/opt/xbmc-bcm/xbmc-bin/share/xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 353, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
xbmc.log(response.text)
14:24:58 T:2811229248 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 347, in <module>
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 347, in <genexpr>
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 172, in ListScenarios
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 52, in GetData
14:24:58 T:3041390592 ERROR: GetDirectory - Error getting plugin://plugin.audio.songza/?mode=1
14:24:58 T:3041390592 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.songza/?mode=1) failed
14:49:35 T:2695279680 NOTICE: -->Python Interpreter Initialized<--
14:49:41 T:2695279680 NOTICE: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>407 Proxy Authentication Required</title>
</head><body>
<h1>Proxy Authentication Required</h1>
<p>This server could not verify that you
are authorized to access the document
requested. Either you supplied the wrong
credentials (e.g., bad password), or your
browser doesn't understand how to supply
the credentials required.</p>
<hr>
<address>Apache/2.2.22 (Ubuntu) Server at songza.com Port 80</address>
</body></html>
14:49:41 T:2695279680 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 348, in <module>
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 348, in <genexpr>
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 173, in ListScenarios
File "/home/pi/.xbmc/addons/plugin.audio.songza/default.py", line 53, in GetData
14:49:41 T:3041390592 ERROR: GetDirectory - Error getting plugin://plugin.audio.songza/?mode=1
14:49:41 T:3041390592 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.songza/?mode=1) failed
14:49:41 T:2695279680 NOTICE: Thread Background Loader start, auto delete: false
