2013-06-06, 00:54
So I've finally sat down to figure out why Frodo was giving me trouble with pseudotv, and I've found out my smartplaylists format I was using in Eden doesn't work under Frodo. For example:
Eden:
Frodo:
I have nearly 100 smartplaylists with the Eden format, and I would really like to avoid having to recreate them for Frodo, is there an easy way to convert them that I'm missing?
Eden:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="tvshows">
<name>Boomerang</name>
<match>one</match>
<rule field="tvshow" operator="is">The Flintstones</rule>
<rule field="tvshow" operator="contains">The Jetsons</rule>
<rule field="tvshow" operator="contains">Scooby-Doo, Where Are You!</rule>
<rule field="tvshow" operator="contains">Looney Tunes</rule>
<order direction="ascending">random</order>
</smartplaylist>
Frodo:
<match>all</match>
<rule field="title" operator="is">
<value>Looney Tunes</value>
<value>The Flintstones</value>
<value>The Jetsons</value>
<value>Scooby-Doo, Where Are You!</value>
</rule>
</smartplaylist>
