Full Version: Windows ☆ Build #2
Image Image ** Special thanks to Beer40oz's original A6-PACK **
[CASE/PSU] ANTEC ISK 110 VESA / 90W ($80)
[CPU/GPU] AMD A6-3500 FM1 65W / AMD Radeon HD 6530D ($63)
[MOBO] ASRock A75M-ITX FM1 USB3.0 SATA-III HDMI eSATA S/PDIF UEFI ($90)
[RAM] Kingston HyperX Plug and Play 4GB (2x2GB) 240-pin DDR3 1866MHz CL11 1.5V ($47)
[SSD] ADATA Premier Pro SP600 32GB SATA-III 2.5" Read:360MB/s Write:130MB/s ($50)
TOTAL: $330
Pros?
* FULL 3D 1080P Ready!!
* Bitstreams DOLBY TRUE-HD & DTS-HD MASTER!!
* 1 x HDMI output!!
* 4 x SATA-III ports!!
* 1 x Optical (S/PDIF) output!!
* 4 x USB 3.0 ports!!
* 2 x USB 2.0 ports!!
Cons?
* no Built-in WiFi!!
* no Built-in Bluetooth!!
* no Multi Card Reader slot!!
That build looks really good, definitely has me considering it. If you wanted to add WiFi, what would your options be? Are there internal options or are you limited to a USB dongle?
at this point yes, you'll need a usb wifi adapter...
these 3 have very good reviews!
- BUFFALO WLI-UC-GNHP ($20)
- Medialink MWN-USB150N ($20)
- B-LINK 150Mbps ($9) ships from HK
well, unless you swap case with one that has an expension slot,
example the ANTEC ISK300-150, and then get a WiFi card.
the ISK300-150 doesn't have a FanLess PSU but,
you could always replace it with a PicoPSU Power Kit like this one --> Here
there used to be a motherboard made by ASUS that had built-in WiFi
like we see often with ZOTAC motherboards, it was the ASUS F1A75-I Deluxe FM1.
but its now discontinued...
At the moment I have my A6-PACK with this Wireless Adapter.... the TRENDnet TEW-684UB Dual Band Wireless N900 I must say I am very impressed. No drops and best of all I am playing my 1080P vids and the router is upstairs. I tested the famous birds test and no drops or anything. By the way my network says its connected at 144 Mbps....
I had the TP-LINK TL-WN722N Wireless N150 and that stutter once in a while and that was connected at 65 Mbps.....
Hope this helps.... Laugh Cheers! M8's
TRENDnet TEW-684UB FTW! Nod
Of-course streaming from my unRAID server.
BTW! I learned that a usb wireless adapter is connected at 1/3 or 2/3 of its actual speed that they say.
nice to hear it works great Beer!!!
Noob question.
Is there any reason why this hardware would not work equally well under Linux / Open Elec and save the cost of Window$?
BTW, I've been googling for 2 hours to find a clear and (nearly) current recommendation for hardware.
