Full Version: Movies not found by scraper..
Hello,
My movies are not found by a scraper..
They are both in a folder with the folder the same name(without the extension) as the movie itself..
Judge.Dredd.1995.1080p.BluRay.DTS.x264-CtrlHD is one of them..
Any ideas?
Kind regards,
Jorricks
Use the proper naming convention
(2013-06-06, 21:38)saitoh183 Wrote: [ -> ]Use the proper naming convention
and what would that be?
just wondering..
Btw I use a copy script which would write it over and over again so do you have any advice on that?
http://wiki.xbmc.org/index.php?title=Add...he_library
I would suggest looking into MediaElch to help you fix your library up Smile
