2013-06-06, 21:09
Is there any way to allow TV show files in the root of a share to be matched based on filename? As I mentioned in another thread, I'm a recent MediaPortal "convert," on MP I used the "MP-TVSeries" plugin to gather TheTVdb info. MP-TVSeries doesn't care where in the included paths something is... there's no specially-named-subdirectory requirement. If it sees a new file it tries to match it, and pops up a dialog with possible matches if something's ambiguous, and allows you to reassign mismatches. Once you've taught it what show a certain naming convention goes to, subsequent ones with different season/episode info are automatically filed correctly.
It seems the Movies section gathers info on files in the root of the share, was hoping there might be an advancedsettings.xml option I'm missing, or something like that.
