HI guys
i need your help
i have an embed code from a stream website how can i put it in XBMC to watch it directly
thank you for your help
I assume you mean an RTMP link or something? Just save the link in Notepad as a .strm file. Save it to a location that XMBC can see then just play it.
thank you for you answer
no is embed code ....
<script type="text/javascript">width=640, height=360, id="G:0101010c070e73706f72743100";</script><script type="text/javascript" src="http://streamtivi.com/jsplayerembed.js"></script>
its support flash by the way
(2013-06-09, 00:54)smel2377 Wrote: [ -> ]thank you for you answer
post the url of the original link
How can i get rtmp code guys please help
Is there any other website that has this channel, it would be better
Check it take any one you want
Streamitivi.com
But all take flash
Is my only solution strm file. And how to creat rtmp file
And what is the differents
(2013-06-09, 04:25)smel2377 Wrote: [ -> ]Check it take any one you want
Streamitivi.com
But all take flash
A website other than that one i mean
Hi my friend
Thank you for help
Why those channels dont work?
Can you show me how can i creat .strm website please? Is there a tool
Or a method to fallow ?
Ok some sites
Www.m6replay.fr
Pluzz.francetv.fr
Playtv.fr/chaine-tv/en-direct/france-2
Tf1.fr/live
I gave you some site
Thank you again for help
(2013-06-09, 16:50)smel2377 Wrote: [ -> ]Hi my friend
Thank you for help
Ok some sites
Www.m6replay.fr
Pluzz.francetv.fr
Tf1.fr/live
The following website that you gave me aren't live they are just videos i need live streaming channel
