Full Version: how to remove Cover/fuzzy overlay?
I like this skin pretty much - only things that bothers me are the cover overlays in video view , the fuzzy overlay on Cd Covers in Music (and the missing Coverflow on music ).
I didnt find any option to turn this off so normaly(lazy as I am) i would go and delete the overlay images out of the media folder, but since its xbt packed and i didnt find any possibilty to unpack it thats no option atm.
Another option would be to go into the xml and mark out the calls but since i have no idea where to search that will be pretty long.
Has anyone another idea?
Thx
Omni
There are a few options:
- You can download the entire skin from the github page and replace the textures.xbt with the uncompressed textures.
- You can edit the XML files (not really that hard)
If you show some screenshots of what you don't like (be sure to turn debugging mode on first - and add clear explanations) I can give you some pointers on where to look.
