Full Version: Jukebox Question - How The Heck Do You Make It Work
Hello all!
First let me say how much I enjoy this skin. Thanks Ronie for all your hard work!
For some reason I can't get the jukebox skin to appear in music. Can someone give me a walk through on how to change the appearance of the music section in xbmc to look like and function like a jukebox? I know this must seem like an easy thing to do but for some reason I cannot make it happen. I have downloaded the latest version of XBMC and within it downloaded Transparency as well.
If I can't get it to work, is there another Jukebox addon that I should consider?
Joe
the jukebox view is only available in library mode.
so, if you haven't already done so, scan your music files to the library first.
Is it possible to change view type on iPad?
(2013-06-14, 21:05)Jmhthefirst Wrote: [ -> ]Is it possible to change view type on iPad?
if you go to skin settings and enable 'touchscreen support'
you'll notice some buttons on the top of the screen will appear.
one of them, the 'list' button, will bring up the hidden side menu
where you can change views.
