Full Version: Power Triggers 2 Opening XBMC with Default Setup Instead of Mine
I'm trying to get my system to shut down XBMC when it sleeps, and start it again when it resumes. Closing works fine using Power Triggers 2, but whenever I try and use the program to start XBMC, I get the default skin with none of my settings (the same as if I started it with the -p switch.) I've tried using it to call a batch file that then starts XBMC with the same problem (even using a batch file to call that batch file). I have run as administrator checked on everything. I'm at a complete loss for why this is happening, does anyone have a clue?
(As a note, I've attempted to use the task scheduler in Windows 7 to similarly start XBMC on wake, but it does nothing; the task is reported as complete (0x0) but no program is started. I'd be happy fixing either one of these problems.)
I have EXACTLY the same problem.
Does anyone have a solution or idea?
