Full Version: custom video nodes
Trying to have a play with custom video nodes. Can successfully create the node to show the videos in a certain directory but in Movies, it shows all movies including those from the custom node although I am using the "doesnotcontain" operator.
below is the text from the "titles" xml found in AppData\Roaming\XBMC\userdata\library\video\movies and at C:\Program Files (x86)\XBMC\system\library\video\movies. note, the xml is identical at each location. Using latest stable release.
<node order="2" type="filter">
<label>369</label>
<path>videodb://1/2</path>
<icon>DefaultMovieTitle.png</icon>
<match>all</match>
<rule field="path" operator="doesnotcontain">c:\3d\</rule>
</node>
I had the same trouble with custom nodes and instead used tags and made playlists that "does not contain" those tags. I renamed the playlists (Movies, Kids Movies, etc) and put them on my home menu and happily segregated my library that way.
