Full Version: Glitches in Menu with latest Intel HD GFX Drivers
Hi there!
I use the actual Frodo 12.2 version of XBMC. I user in the past always the Intel HD Graphics driver v9.17.10.2932 but after problems (disable every time YCbCR mode after shutdown the LED-TV) I upgraded to v9.18.10.3165. But the 9.18.10.3165 do some glitches in the menue like black or colored lines, missing/bad loadingbars or other glitchy things.
Here a screenshot:
This is the AEON NOX theme but it's the same with the default theme.
But I should say I use Lucid Logix MVP Virtu what is bundled with by ASRock Z77 Pro3. I use only my Intel HD Graphics 2500 of my Intel Core i3 3220 instead of my HIS AMD Radeon HD 6950 IceQ X Turbo. It's still the same problem even I disable or enable MVP Virtu.
The issues appearing only in XBMC. I tested the graphics with PassMark BurnIn Test in 2D and 3D and there are no glitches.
What shall I do now?
It's a Intel driver problem so you'll need to rollback to the previous drivers, see https://communities.intel.com/thread/386...0&tstart=0
