2013-06-16, 19:12
Hello
I run Openelec/XBMC on a mini PC plugged into the VGA port of a TV device. I use "suspend" rather than "shutdown" when not in use.
The problem is that when the PC suspends itself, it also put the TV screen in sleep mode. It could be nice if I had no problem with the Harmony remote afterwards: indeed when the TV screen is in sleep mode and the PC in suspend mode, the remote fails to switch the TV entry (e.g. to HDMI) after wake command, because the TV screen again goes into sleep.
I tried several solutions with the remote, but nothing really successful. The simplest thing would be to prevent XBMC to put the TV screen into sleep mode when it suspends itself, is it possible ? Thanks.
