Full Version: font size?
hey question I use the tri-panel view for movies is there a way to increase the front size on the movie list and the plot?
Thanks,
Yonu
That view has several options. Which one do you use ?
In any case the file for that view is the Viewtype_Tri_Panel.xml. You can play there with <font>XPM_font_xx</font> tags to adjust the font size where you want it.
Cheers
Nessus
