2013-06-20, 14:15
Hi really weird issue, a few nights ago I noticed the watched indicator was wrong for one of the TV shows I have. It was showing 8 unwatched, when there should be ~30. I went into the folder and season 1 and half of season 2 are missing, XBMC is showing them as a single folder instead of two. I did a library update, it did not add the files back. I manually refreshed the folder and they reappeared but lost watched status. Then I started poking around and more then half my shows are like this.
At first I thought one of my source HD's went to sleep and XBMC was hiding them, I checked both my external HD's and they are working fine. I don't know if the DB was corrupt somehow? Everything else seems to be working. Running XBMC on a 512MB Raspberry Pi (rbej OE 12.2 build). Files are stored on two USB hard drives connected to a second Pi (Raspbian, latest), both Pis are connected to my router via ethernet.
Example:
\TV\Show\Season 1\3 episodes
\TV\Show\Season 4\6 episodes
(I have the entire series, 7 seasons all episodes).
Some folders seem to have only kept unwatched episodes, where others have random seasons and random episodes in the seasons. Doing a library update doesn't bring them back only a refresh by folder does. Anyone know what might have gone wrong and if there's an easier way to fix then manually refreshing every folder and marking as watched?
Example:
