I have loaded 12.2 running on Win 7 64-bit.
I would like to run the transparency skin but its not showing as available.
Thanks for any help
do a refresh on the xbmc repo.
Matt
thanks Matt, it's working now.
I am new to xbmc and although I knew I needed to do a refresh, I couldn't figure out where to go or how to do it. There is a lot of back and forth between menus in xbmc and it's not very intuitive.
Thanks again
Glad you got it working
i think its very intuitive tbf.
my misses can use my htpc but she cant use a laptop very well.
Matt
I have the same issue as gotexans I think, but am not bright enough to know what
"do a refresh on the xbmc repo"
actually means.
I have just installed 12.2 on win8 64 bit machine - when i go to "get more" under skins there is only Confluence there.
Can you expand on "do a refresh on the xbmc repo" please
