2014-01-19, 01:51
Well I can login again to youtube that fixed but de rss feed part does not work because of this script.rssclient,guiless any idea ?
(2014-01-14, 21:18)toyota12303 Wrote: [ -> ]Thanks for the comments !
@grote345 : At the moment you can only snap videos and music, but i will look into adding snappable apps.
@QueK9 : Thanks! And it should all run fine on openelec as i have tested it on Ubuntu Linux and all worked fine apart from anything using the web browser. And i have also tested it on Gotham Alpha 11 and it all worked fine apart from if you open up the context menu on the games/apps section it will crash, but i will try and make a fix for this. The Live TV PVR functionality is supported and should be working fine and i will be soon adding something like the Xbox One Guide into it as well
@iAMl3dgend : Yeah but you will have to manually edit your keymap xml. You will need to find : <button id="5">ContextMenu</button> on the first section and change this to : <button id="5">XBMC.ActivateWindow(55)</button> (This will open the charms bar from the lb burron) But i recommend mapping it to the start button or something instead because you will then not be able to open the context menu from your controller. Or you could download my keymap xml that i have created (http://www.mediafire.com/download/p0i7h1...roller.zip) this already has both buttons mapped
@kingkearney : This should already be running fine on openelec as i have tested it on linux and it all worked fine apart from the web browser section.
@chisharpe : That screenshot was from a really old version of the skin and it has completely changed now. Also the trakt.tv feature can be disabled from the settings (alternative ads) this will disable trakt.tv and enable local content from your system.
@kingkearney : If you are experiencing dependency issues then you will have to make sure that you have deleted the previous version of my skin, copy over all dependencies to the addons folder. And if you are still experiencing the same problem then this addon.xml may fix it (you will just need to copy this to the skin folder) : http://www.mediafire.com/view/xny7gzyweg67xw5/addon.xml
Also i should be uploading an update in a few days that will be fixing a few problems
(2014-01-29, 00:19)chisharpe Wrote: [ -> ]updates?[/align]
(2014-02-06, 13:27)Vahid_PC Wrote: [ -> ]help please..
