Faboulous Job! :3
the tiles on the 'my pins' and the other sections will be changeable/customizable like on Xperience 1080?
also, the Games area works with advanced launcher?
Thank you and yes once i have finished adding the rest of the updating adverts then i will make them & the pins customizable to videos,music,apps,games,pictures ect and you will also be able to pin websites to them aswell & i might try and add an option to add and position items on the dashboard. e.g. you could pick a video app or movie in the settings and pick the size and where you want it positioned on the dashboard and launch it from there. but i dont know if this is possible yet i haven't tried it out.
& yes when you go to games it will open advanced launcher and i am going to try and make the game dashboard adverts feeds from youtube channels like ign. also when you play a game it will show up on your recent on the dashboard and you will be able to launch it from there aswell
& i have also added a gameinfo window & a feature so when you launch a game it will fade into the game like the xbox and when you return it will fade out back to the dashboard.
(2013-07-17, 16:34)toyota12303 Wrote: [ -> ]& yes when you go to games it will open advanced launcher and i am going to try and make the game dashboard adverts feeds from youtube channels like ign. also when you play a game it will show up on your recent on the dashboard and you will be able to launch it from there aswell
added a search button on the charms bar to search youtube
fixed mouse support
changed animations
some adverts like the main ones get updated every time you log in and the rest i still need to change
integrated the gamertag script - you can enable this in the settings (if you use this feature you will need to change your profile name to your xbox gamertag)
added a dialog for viewing your recent achievements, gamerscore, and avatar - this is far from finished so it looks pretty bad at the moment but works
some of the things i still need to do:
finish adverts
link a ign feed to the games section of the dashboard
add setting for customizable items
add customizable pins
skin the irc chat
change the views for games,videos,music & pictures
Thankyou for testing my skin & feel free to post any suggestions or anything
There are a few things i forgot to do :
-- 2 buttons in the settings window = setup controllers & voice control
at the moment they dont work but but i will be linking the voice control to windows so you can browse xbmc with your voice.
- also the downloads button in the charms bar doesn't work at the moment i still need to link that to the currently downloading addons.
Any problems or bugs could you please email me at : [email protected] and i will try to fix them
i have fixed the recent section of the dashboard so when your watching something you can minimize it to there and open it again like the xbox. - also has pretty much same animations
i have also fixed those buttons that dont work.
and if anyone gets problems with the adverts not showing up its because you need this file from here : https://dl.dropboxusercontent.com/u/3687...edinfo.zip
you can extract this to your addons folder or in xbmc you can select install from zip.
just downloaded and tested the zip: that home animation, that home animation is freaking awesome!. kudos!
- i think tv and movies could look/work better as separate pages. and instead of static tiles, you could use skin.widgets to populate the pages with user content (latest episodes/random episodes/watchlist on the recommended sidebar /random tv shows/favorites on the square tiles on the bottom) it would look great with landscape/fanart), for the other tiles, you could use something like black's xperience1080 tile customization (backspace on tile shows customization options/etc),
- disable RSS option is missing.
thanks for releasing it for testing. keep up the good work
