ADHDMedia : It must have something to do with XBMC then. I think that it might be something to do with the amount of settings ect. I should hopefully be uploading an update some time today. I will also upload a different version of the update that has a smaller amount of options.
grote345 : Thanks!
senna99 : Thanks!
ADHDMedia : Yeah you could try removing forum browser and see if you still experience the problem. Though i don't see why it would effect just the dashboard and not other sections.
senna99 : I have just recently found a solution to this and integrated this into my games and apps section of my skin. I have done it by using demo\wheel\$INFO[System.UsedSpace].png and then created 100 wheel icons and named them 0 % Used to 100% Used and placed them in to the media\demo\wheel folder. You can just copy the icons from mine if you want to. The same should work for ram/cpu usage by using e.g.
@Dom DXecutioner : Thanks for that! This is working perfectly now.
Also do you know if it is possible to get an xbox live friends gamerpic on XBMC ?
I have recently been trying to add your own friends to the friends section and I have tested out all of the below to get the gamerpic but it fails to display the icon.:
http://avatar.xboxlive.com/avatar/$INFO[Skin.String(Friend1)]/avatarpic-l.png
https://avatar.xboxlive.com/avatar/$INFO[Skin.String(Friend1)]/avatarpic-l.png
www.avatar.xboxlive.com/avatar/$INFO[Skin.String(Friend1)]/avatarpic-l.png
http://www.avatar.xboxlive.com/avatar/$INFO[Skin.String(Friend1)]/avatarpic-l.png
https://www.avatar.xboxlive.com/avatar/$INFO[Skin.String(Friend1)]/avatarpic-l.png
bakito : I think that it may have something to do with the amount of skin options as my skin has around 400 options and all of these have to be loaded from the guisettings.xml when you switch to it. I will be uploading 2 versions with the next update : 1 that has all skin settings and another one that has lots of options removed as this may fix some problems.
grote345 : This happens when it can't download the bing image in the startup time. In the next update i will add an option in the settings to have long boot, medium boot or short boot. The longer boot option will just take a few extra sections to boot up and this will make sure all images are downloaded by the time it reaches the dashboard.
The medium boot will just be the current startup time.
The short boot will take about a second or less to boot, this would be good for people with very fast internet but for others it may not be able to get the images in that time.
I should hopefully be releasing the next update today with 2 versions a minimal one (less settings) and a normal version (all settings)
In the latest update it includes :
Options for boot times - short, medium and long.
Options to disable startup items
Better option to change colour (see image below)
Added wheel to games & apps section displaying used HDD space (see image below)
Options to update on startup (update library, update addons, update repos, refresh weather)
Extra colours
Extra gamerpics
I will also try to include an option for a different charms bar, but i am not sure what how i want it looking at the moment.
I will also be trying to include the dependencies inside the skin so that you won't have to download them. They will all get extracted when the setup is ran.
Here are a few previews of how it's looking :
