Hahah, it took me months to find a solution for the guide button!
Another thing that would be perfect for anyone using a controller. I am currently developing is a shell for windows, this uses a modified version of my XBMC skin for the interface and has a massive set of scripts that will manage everything on your system for you in the background.
You can use a controller for anything at any time,
The shell cleans temp files, defrags ram, sets unused services to manual, and overall optimizes your system to the max.
By default windows uses around 1-1.5gb ram, with my custom shell that i am currently developing it uses 450mb and at the lowest i've got it down to 320mb.
Cpu usage is around 0-1% at idle.
Optimized web browser for Xbox Controller - Kylo.
registry tweaks to improve fps in games.
And much more!
It is still in a really early version and isn't very stable yet. But it's starting to come along nicely and should hopefully be released some time soon for testing!
Here is a little program that i have created that will install all the required files for the Xbox Guide button :
http://www.mediafire.com/download/8yt35m...boxGui.exe
You just run through the setup, and then instead of launching XBMC from the XBMC.exe you will need to navigate to C:\Launch.exe and this will launch all of the scripts alongside XBMC.
If you are creating a shell then you will need to set the shell to C:\Launch.exe and not XBMC.exe
Here is a copy of the steam script :
http://www.mediafire.com/download/d89vaa.../steam.exe
This will close XBMC and launch steam, once steam is closed then xbmc will start running again.
To launch it from XBMC go in to skin settings and set steam.exe location, then choose this .exe instead of the default one.
(Steam can be launched from the steam section in this skin)
Don't use the steam script actually i have just noticed i misread your previous post i set it up for C:\ but yours is on F:\ 2 seconds i will quickly change it around.
Also i will quickly create one for onlive and Hulu, they are very easy little scripts to make!
