grote345 : I'm really not sure why it's still not working as i am also running Windows 8.1, Internet Explorer 11 and XBMC Frodo, i will keep looking in to it though.
panta08031 : Have you tried going in to the skin settings and ticking the "link xbox gamertag" option and then signing out and back in ?
(This will run the script every time you start XBMC)
bakito : Yeah i could add an option in the next update to have scrolling fanart for your TV shows & movies on the dashboard.
panta08031 : The video player is part of XBMC and not part of the skin. Do you have the same problem playing the same video on a different skin ?
ADHDMedia : Yeah i thought that it should be like that too, but when i watched a video of the Xbox One being set up it was the email and password that came up first.
And as for the kinect set up i will add an option to skip this in the next update.
@johnb :
Hi John,
Yeah i am still working on that section as i can't have the texture border above the actual texture because when a video is playing and you click on it the border goes weird and doesn't look right.
I should hopefully have this all sorted and working for the next update.
As for the label backgrounds i can add an option in the settings on the next update to enable full width label backgrounds.
And as for the favourite tiles having labels, yeah sure i could add an option in the settings to enable this. The reason that i didn't in the beginning is because if you have a favourite that's got bright colours then you can't see the text properly.
And as for the now playing option i have recently added a feature where anything that you play will be on the main dashboard tile, this could be music, radio, video ect.
babesumitra : The live tv section should be working fine, but if it isn't then there is an option in the settings to set an alternative video plugin or program to use instead.
ADHDMedia : As for the fading in and out of a game, this feature is already added in there. You just need to go in to the settings and disable the "enable game splash" option. This will then show a black fading screen instead of the game fanart when launching.
(You need to launch the game from the info section for this to work.)
And the "opening stream" text can be disabled in the advanced launcher addon settings as this isn't part of the skin.
I think it's the option that says "disable starting game notification" or something similar.
Angelscry : Currently from my skin i have got it set up to use the RunPlugin() option, so am not sure why it is displaying the "opening stream" text. Unless in the advanced launcher settings the notification option is turned on.
