Nope pretty sure he means our own info from our trakt.tv accounts…?
Hey guys! Put together a little video of how I'm using this incredible theme… everything is controlled via XBox 360 Wireless game pad. Check it out!!
http://youtu.be/470snpvQ0HE
Just updated to a GTX 660, able to run all games in max settings 1080p. I'm a pretty happy camper. I don't play COD much so don't laugh too hard
Nice video!!
How do you make steam start as xbmc? I startt it from xbmc but it seems to start as xbmc start which is nicer!
Cheers
I launch steam first and then launch XBMC from within Steam. So when I launch it from XBMC, it's already open.
Basically, steam is always running in the background. That way, if I launch a Steam game from within XBMC it will still work.
Can you add a scan for new content button in the xbox video section?
also could you add some better views i really dont like the current ones?
I would also appreciate some more views. A better grid style view, something like the Confluence grid style would be cool. Vertical scrolling and such.
Hi Toyota. Look forward to the updates. Those options would be great.
Is it possible to auto sign-in? I know sign in can be disabled, but i was wondering if a user could be set to sign in on startup?
ADHDMedia : Ohh right, that isn't possible at the moment and i am not too sure on how to do that yet as my python skills aren't very good.
ADHDMedia : Great video man! I love how you have got steam integrated in with it. Also how did you get your Xbox controller working with MW3 ? The only solution that i have found for this is to use Xpadder, Pinnacle or other software.
iAMl3dgend : Yeah sure i will add this in to the next update, and for the views i will be improving them soon.
@johnb : Yeah you can just go in to the settings - startup options - disable log in screen. That way when you start up it will skip the log in screen and put you straight in the dashboard.
(You will need to download the disable sign in fix from page 1 to get rid of the sign in button)
iAMl3dgend :
Great work!
How did you get the osd progress bar looking like that ? (With the little little circle thing)
I have tried this before and it kind of worked but the little circle was in the wrong position for the first few seconds of the video, until the progress bar started moving.
Here is how i attempted to do it :
PHP Code:
<control type="slider">
<posx>17</posx>
<posy>-34</posy>
<width>735</width>
<height>10</height>
<texturesliderbar border="0">colors/color_transparent.png</texturesliderbar>
<textureslidernib>colors/leaf.png</textureslidernib>
<textureslidernibfocus>colors/leaf2.png</textureslidernibfocus>
<info>Player.Progress</info>
<action>seek</action>
<controloffsetx></controloffsetx>
<controloffsety></controloffsety>
<pulseonselect></pulseonselect>
</control>
Also that Xbox Music section is beautiful!
Any chance i could get a download link for the Xbox Music section ? as i would love to integrate this in to my skin, if that's alright.
I'm using XPadder for pretty much everything that doesn't have native control, like chrome and MW3. BF4 has built in controls. If you like I can upload my profiles?
Oh and also - I'd love it if you could just add the subtitle and video settings to the original alt OSD. It works a lot smoother than the new one.
That music section would really top off this fantastic skin!
Oh ya - @toyota feel free to add that video on the first post if you want to use it as a demonstration. I don't mind!
