Full Version: [BETA] Mail (XBMC Mail Program-Plugin)
Pages: 1 2 3
Thanks for the reply, another great add-on by the way :D
Hello all, I haven't really done much with XBMC on my ATV2 in a couple of years although I'm using it often to watch movies... I tried installing the app but I'm getting "dependency not met". Im on an older version (Darwin 11.0.0). Any hints on what I might need to do to get this running?
Thanks all in advance.
All, nevermind - i upgraded to Frodo and its working now. Very cool!
(2013-07-22, 18:07)nealsil Wrote: [ -> ]All, nevermind - i upgraded to Frodo and its working now. Very cool!
Yes, Its Frodo only.
For me, unfortunately, the plug is not working http://pastebin.com/dNr374dE
(2013-09-12, 21:54)jon123456 Wrote: [ -> ]For me, unfortunately, the plug is not working http://pastebin.com/dNr374dE
I don't see anything regarding my Mail Add-on. From the logs you try to open the Facebook Media Add-on.
(2013-07-09, 17:19)blondeshanks Wrote: [ -> ]Hi,
I can see great use for this, being able to check emails within xbmc is a great feature but I wonder will this add-on support hotmail/outlook sometime in the future or is this not possible?
Outlook supports IMAP now: http://blogs.office.com/b/microsoft-outl...-imap.aspx
Sending correct the error log http://pastebin.com/MiAUkTi8
(2013-09-13, 08:26)jon123456 Wrote: [ -> ]Sending correct the error log http://pastebin.com/MiAUkTi8
Interesting, same error like the facebook add-on has (from your previous log). Your Python is missing the email.parser module. It is part of the standard modules since Python 2.5 (XBMC comes with 2.6).
Do you have external Python <2.5 installed?
I have nothing installed only was updating xbmc
Greetings to all.
I need help to solve some problem, how to get string id from plugin.programm.xbmcmail for Email in box,to be visible in the home panel like on xbox 360.
Thanks in advance
http://i.imgur.com/8rqS7Lu.png
(2013-09-13, 08:52)jon123456 Wrote: [ -> ]I have nothing installed only was updating xbmc
Sorry, but I can't do anything against your problem, your Python installation seems broken.
(2013-09-13, 11:27)senna99 Wrote: [ -> ]Greetings to all.
Thanks in advance
I don't get your question.
I just need label information for inbox mail,like gmail notification addon .
Can display in home menu in box number of mail.
I am sorry I don't know how to better explain what I want.
Hey I am running Frodo and I am getting Dependancies Not Met when I try to install it from the zip file.
Any ideas on what I should try?
Thanks in advance
(2013-09-16, 14:36)senna99 Wrote: [ -> ]I just need label information for inbox mail,like gmail notification addon .
Sorry, I don't understand what you need.
(2013-09-22, 00:33)theone964 Wrote: [ -> ]Hey I am running Frodo and I am getting Dependancies Not Met when I try to install it from the zip file.
Thanks in advance
Just install it from the official xbmc.org Add-on Repository.
Great Gmail addon , but How to display email in other language, e.g. Japanese , Chinese) , Step in setting please , Thanks
Pages: 1 2 3
