I have developed an Email-Add-on.
With this Add-on you can read your emails from within XBMC, all you need is an email provider which supports IMAP (most do).
Current features
- Email provider-templates (Gmail, Yahoo, iCloud). You only need to choose your provider and set username/password. Or you choose custom and set the imap-server-host manually.
- List Mailboxes (INBOX, Drafts, Trash, ...) incl. "Total/Unseen" stats.
- Flag Emails as seen/unseen (reading emails flags them as seen, too)
- read Emails (at least the text part, but most emails contain html AND text)
- delete Emails (you will be asked if you are sure before anything gets deleted...)
I would be happy if you could test it and give me some feedback!
Also, if you need more provider-templates, just tell me the data (or open Pull-Requests at
Github).
As always, later in the official repo, now only .ZIP:
Changelog:
Quote:0.1.0 (05.07.2013)
- added Mailbox Pagination
- fixed GMAIL Virtual Folder
- fixed Mailbox Name decoding
- cosmetics
0.0.1 (22.06.2013)
- initial release
Version 0.1.0
regards,
sphere
Going to install it now. Could be handy.
I don't see it in feature list but maybe (password protected) multiple accounts is something for next versions?
Edit:
Url is broken
http://%27http//goo.gl/HfEkq'
Edit2:
A few things i noticed:
Seeing this regular
13:04:19 T:6728 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(plugin) in plugin://plugin.programm.xbmcmail/mailbox/INBOX/73/show/folder.jpg
When opening mailbox folder named
[GMAIL] (0/0)
http://pastebin.com/arAnBqCM
Wanilton
Fixed it myself but for upcoming users
Schumi2004, Correct URL for download:
http://goo.gl/HfEkq
Thanks Sphere, I will check this new resource soon.
URL is fixed, thanks!
The error messages you see:
is a bug in xbmc core in combination to xbmcswift based plugins. Its harmless and only cosmetic.
The "[GMAIL] (0/0)"-thing is a Gmail special thing, I will hide this non-mailbox entry in the next version.
Multiple accounts is something I already thought about - but it would make things much more complex. I don't think that it will be added soon.
And btw, forgot to say that when the add-on works stable enough it will use caching (caching makes debugging much harder, thats why it isn't already included).
Thanks for your feedback,
sphere
Thanks for explaining sphere and for the addon off course
So far it runs smooth with Gmail, going to try it with my ISP account in a few but won't expect any issues.
Multiple accounts is not something i really need, can life without it.
Something that would make it perfect (but you probably already have this on your todo list) is compose emails?
(2013-06-22, 13:43)schumi2004 Wrote: [ -> ]Something that would make it perfect (but you probably already have this on your todo list) is compose emails?
Yes, maybe later. Problem is that XBMC doesn't provide any "multiline editable Text"-dialog, just the modal keyboard-dialog.
Of course there's the Edit-Control - but this would need a custom window which would need to be designed and skinned.
Originally I planned to create this add-on as script with an own GUI - but I was not sure if this would be worth the work needed.
regards,
sphere
Hi sphere
My debug log
http://pastebin.com/11eYQB6y
But I think it´s the same think related by schumi2004.
Using XBMC Gotham, windows, skin ace.
Work fine with gmail.
Wanilton
New version ready.
Changelog:
- cosmetics
for Download link see first post.
Thanks, going to test it asap.
(2013-07-06, 12:51)schumi2004 Wrote: [ -> ]Thanks, going to test it asap.
Hmm I can't get it to work, I'm installing it from Zip and i get a message down in the Right Corner saying Dependencies Not Met. Im running Eden.
(2013-07-06, 18:38)theone964 Wrote: [ -> ] (2013-07-06, 12:51)schumi2004 Wrote: [ -> ]Thanks, going to test it asap.
Ah yes, its Frodo only atm.
EDIT:
And the Eden Repository is closed for new add-ons so a backport won't make much sense. Sorry.
I can see great use for this, being able to check emails within xbmc is a great feature but I wonder will this add-on support hotmail/outlook sometime in the future or is this not possible?
This Add-on uses the IMAP mail protocol, so it supports every email provider which supports IMAP.
Afaik hotmail and outlook don't support imap, only POP3.
(2013-07-09, 17:24)sphere Wrote: [ -> ]This Add-on uses the IMAP mail protocol, so it supports every email provider which supports IMAP.
So POP3 support is not planned or not possible?
(2013-07-09, 21:04)blondeshanks Wrote: [ -> ]So POP3 support is not planned or not possible?
Possible is everything
Its not planned at the moment, maybe later.
