I'd love to see the "Green Button" incorporated - ie so that out of the box, xbmc launches from the microsoft remote - I see there is a box you can tick on NextPVR to do that - so I'm sure xbmc could too!
Yes I did search and find various complicated solutions.. but nothing I fancy trying
that's got nothing to do with xbmc.
Install the registry hack/workaround and it should work.
It's a easy installer so not that hard to install.
Use it with a mce receiver and my harmony
Hi TRaSH, do you mean this: XBMCCustomregis Setup v2.60.12 ?
I haven't looked into the launcher yet, but I gather it is for all sorts of apps too? Could be useful.
I'm using a proper rc6 and most of the functions already work since I used the mc remote option in Frodo.
Yes that's the one I use with my mce receiver and Logitech remote
