Full Version: What's the point of the '+' and '-' buttons in 'Settings->Channels'?
I'm trying to work out the point of the '+' and '-' buttons in 'Settings->Channels'.
Having set up the device, the channels are in the original, chaotic order.
I spent ages reordering them with the '+' and '-' buttons, checked the EPG, still in the wrong order.
I thought, OK, there's an 'Update EPG' button - That makes sense if you've just re-ordered everything.
After the update had finished, all of the channels were back the way they were.
I thought, OK - That didn't work out quite the way I thought it would, I'll just have to re-order them again.
Using the '+' and '-' buttons again, I moved the first 4 channels up to the correct order, clicked OK, checked the EPG, same old order.
Closed & restarted NPVR, and the channels are in the wrong order again.
What are the buttons supposed to do please? I'm obviously misunderstanding their purpose.
(Currently writing out all the channels, giving them a number, double clicking each one, changing the number, saving it... hmmm... that can't be the right way, can it?)
Many thanks,
Pauliolio
