Full Version: Modify Confluence Live-TV Menu
I would like to change the Confluence Live-TV Menu but am totaly new to xbmc-skinning and would like to ask if what I want to achieve is even possible or if it already has been done (maybe in another skin?).
The reason:
My wife hates the Live-TV menu and becaue of it refuses to use XBMC to watch television.
I kind of agree with her because I think that the Live-TV Menu with its left hand Menu for Guide, Timer, etc. breaks the flow of the Confluence skin.
Normally, these side menus only hold setting relevant to the look of the current view.
I would like to get rid of it entirely.
"LIVE-TV" should go directly to fullscreen playback of the first television channel.
"TV-Channels" should be renamed "Guide" and should go directly to the EPG/Guide-Window.
"Radio Channels" shoudl be removed.
"Timer" should go directly to the Timers View.
So, if I understand correctl, all I have to do is change the targets of these buttons, rename TV-Channels to "Guide" and remove the "Radio Channels"-button.
Correct?
Thank you for any advice/comments.
rw
