Full Version: [Release] IMDb Update (Movie Ratings + Top250 + MPAA) *Jarvis*
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
(2015-02-27, 19:01)ronakg Wrote: [ -> ]Yes, that setting is enabled.
Ok, what exactly is "Genesis" ?
(2015-03-02, 22:50)Jandalf Wrote: [ -> ]
It's one of the popular addons for watching Movies and TV Shows. (http://addons.tvaddons.ag/show/plugin.video.genesis/)
It allows adding Movies and TV Shows to library directly from the addon.
(2015-03-02, 23:18)ronakg Wrote: [ -> ]
It is also one of the banned add-ons.
(2015-03-03, 00:54)wgstarks Wrote: [ -> ]
(2015-03-02, 23:18)ronakg Wrote: [ -> ]It's one of the popular addons for watching Movies and TV Shows. (http://addons.tvaddons.ag/show/plugin.video.genesis/)
Oh okay. I didn't know that. Why is banned, if I may ask? Should I assume that it won't be supported as it's banned?
(2015-03-03, 01:17)ronakg Wrote: [ -> ]Oh okay. I didn't know that. Why is banned, if I may ask? Should I assume that it won't be supported as it's banned?
Forum rules.
can anyone tell me what i am doing wrong i get the following message when trying to launch this
the php-cgi binary wasn't found in your system
(2015-03-26, 09:31)knives of ice Wrote: [ -> ]can anyone tell me what i am doing wrong i get the following message when trying to launch this
are you sure you installed this plugin and not Rating Update http://forum.kodi.tv/showthread.php?tid=107331 ?
my add-on does not use php-cgi but Rating Update does.
Awesome Addon Smile
When its update TV Series/Episodes in the Future its perfect.
Thank you for your work.
That addon is great and I enabled the weekly update... and for some reasons the addon thinks weekly means each 30 minutes? ^^
I watched an 3hour movie yesterday and I don't know how often I got the notification that the script is updating while I was watching it.
(2015-03-30, 11:07)sualfred Wrote: [ -> ]That addon is great and I enabled the weekly update... and for some reasons the addon thinks weekly means each 30 minutes? ^^
ok, could be a a language/country problem, could you try this version: https://drive.google.com/file/d/0B_M7-Lm...sp=sharing
Yep, I will keep you updated.
Nope, the same. Updating works great, but the script runs itself after a few minutes. Again.. and again Smile
with the help of sualfred its working again:
script.imdbupdate-0.6.0.zip
v0.6.0 (2015-04-02):
- added start parameter for skinners to run all updates
- fix date parsing issue
Helix 14.2 error:
"Add-on does not have the correct structure."
(2015-04-03, 16:03)HeresJohnny Wrote: [ -> ]Helix 14.2 error:
I'm getting the same error
