My plugin returns nothing... no update... How can i fix that?
20:51:33 81474.882812 T:1415103520 ERROR: [IMDB Update] - Aladdin: problem with omdbapi.com
20:51:33 81474.960938 T:1415103520 ERROR: [IMDB Update] - The Amazing Spider-Man 2: problem with omdbapi.com
20:51:33 81475.085938 T:1415103520 ERROR: [IMDB Update] - Avengers: Age of Ultron: problem with omdbapi.com
Have you updated to the latest version?
Looks like they might be a problem with omdb.com api. What was you trying to update? Top 250? Mpaa? Or Rating or all of the above. Might be better to try 1 by 1 to help find the problem.
Any change of including option to update TV Shows as well, or is there another plugin for that ?
(2015-10-08, 21:14)raspdealer Wrote: [ -> ]Hi,
I am using the latest version and am getting the same errors in my log.
Hi!
Started to add the positions by hand in the nfo files. But when I reached 20 I thought there has to be an easier way. And so I found this wonderful plugin. Thanks a lot!
It adds and updated the Top250 positions flawlessly but it throughs an exception when it is finished. What does it mean?
15:09:52 T:1562461888 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.OSError'>
Error Contents: [Errno 2] No such file or directory
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/default.py", line 63, in <module>
gui()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/default.py", line 18, in gui
stop = Top250().start()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/resources/lib/top250.py", line 34, in start
self.startProcess(movies, length)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/resources/lib/top250.py", line 72, in startProcess
util.openFile("missingTop250.csv")
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/resources/lib/util.py", line 205, in openFile
subprocess.Popen(os.path.join(addOnProfile, name), shell=True)
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/subprocess.py", line 633, in __init__
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/subprocess.py", line 1139, in _execute_child
OSError: [Errno 2] No such file or directory
I have Kodi 16.2 installed on a FireTV.
Cheers!
(2015-10-30, 16:22)P_Jamula Wrote: [ -> ] (2015-10-08, 21:14)raspdealer Wrote: [ -> ]Hi,
Same deal. It's omdbapi.com. I don't think I've seen any ratings change.
Same problem here:
Quote:13:49:06 T:10960 NOTICE: [IMDB Update] - Starting IMDB Update v0.8.8
13:49:10 T:10960 ERROR: [IMDB Update] - Abgedreht: problem with omdbapi.com
13:49:10 T:10960 ERROR: [IMDB Update] - Alles eine Frage der Zeit: problem with omdbapi.com
13:49:14 T:10960 ERROR: [IMDB Update] - Birdman (oder die unverhoffte Macht der Ahnungslosigkeit): problem with omdbapi.com
13:49:15 T:10960 ERROR: [IMDB Update] - The Contract: problem with omdbapi.com
13:49:15 T:10960 ERROR: [IMDB Update] - Crazy, Stupid, Love.: problem with omdbapi.com
...and so on
This happens to 37 of 1180 films, so I think it's not a big issue. Any idea how to solve the problem?
Don't forget the top 250 can be done with Video Nodes as well
See my signature.
I tried it with today's nightly (between Jarvis beta 5 and RC1), but installing fails. Some error message, can't remember it all, but it notified me 'gui incompatible'. Is this Jarvis proof?
Where is the difference to the Addon from m4x1m
EDIT: ok, now i know. His one is not working...
Yours is working fine! Thanks for that addon. Really great.
Any chance of a Jarvis release of this?
Works perfect for me with Android Kodi Jarvis 16.0 RC 1 and RC 2.
getting installation error I am running Jarvis latest version with windows 10 Pro. I get following error
"failed to install the dependency on xbmc.gui version 5.30 could not be satisfied"
By default there is no separator for thousands in the number of votes, so my 1st update has listed all my movies without a separator, for example 200000.
So i went into settings, and changed the thousands separator to "," and tried to update again, however 0 movies were updated and no "," were added. So instead of them now reading 200,000 they still read 200000. Im guessing cause it only updates entries with 1% change to the votes etc.
This is very annoying, i even tried uninstalling the addon, installing it & running it again so it would think it was the 1st run. This did not work.
How can i add the "," separator to the thousands votes?
