I had this add-on working then all of a sudden I started getting errors after a couple of movies. I uninstalled and tried to reinstall and now I get the following error:
Here is the error on the spmc.log:
ERROR: CAddonInstallJob[script.imdbupdate]: The dependency on xbmc.addon version 16.9.701 could not be satisfied
I am using SPMC and IMDb Update v0.8.10 (2016-03-17)
Any help would be greatly appreciated as I really like this add-on and can't figure out how i botched up my Kodi install
Is there a way to hide the notification and have this just run once a week in the background?
Hello,
I would love to manually add to my modified skin the scanning of a single movie. In the old Rating Update, I had a parameter to do this that read:
<onclick>RunScript(script.ratingupdate,Single=Movie)</onclick>
This does not work when changing to
<onclick>RunScript(script.imdbupdate,Single=Movie)</onclick>
Is there a way to do this please?
Many thanks,
H.
The ad-don works successfully on SPMC 16.4.2 on Nvidia Shield. However, as stated here at post
#34 by the add-on creator that the votes are 1 week behind, so the votes you see in IMDB website might not be same as the updated IMDB votes in your KODI/SPMC.
Thank you for the great add-on.
HI,
after installing IMDb Update 8.10 on my Android TV-Box (Android 5.1.1/Kodi Jarvis 16.1) get the following error trying to Update Top250
06:44:23 T:18446744072308703120 NOTICE: [IMDB Update] - Starting IMDB Update v0.8.10
06:44:37 T:18446744072308703120 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.OSError'>
Error Contents: [Errno 2] No such file or directory
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/default.py", line 63, in <module>
gui()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/default.py", line 18, in gui
stop = Top250().start()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/resources/lib/top250.py", line 34, in start
self.startProcess(movies, length)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/resources/lib/top250.py", line 72, in startProcess
util.openFile("missingTop250.csv")
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.imdbupdate/resources/lib/util.py", line 205, in openFile
subprocess.Popen(os.path.join(addOnProfile, name), shell=True)
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/subprocess.py", line 633, in __
init__
File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/subprocess.py", line 1139, in _
execute_child
OSError: [Errno 2] No such file or directory
any idea?
Thank in advance.
(2016-10-30, 20:16)junitodx Wrote: [ -> ]Hi,
+1 about this.
Cannot install because dependency not met. Last Krypton beta.
Any help please ?
When I show the Top 250 results in the movies that I have but not the position of the ranking. Can I configure that?
Thanks in advance.
When I try to use this with Krypton (stable) I get an error about dependency not met xbmc.gui 5.10.0... any suggestions?
The modded version worked with Kodi 17 RC4, but now the addon won't update my ratings.
Some thing to edit?
Its not been working for some days now...
Says Scripts failed.
(2017-02-09, 18:05)Simkin84 Wrote: [ -> ]Its not been working for some days now...
I have the same problem. Update stops after a few seconds with Script Failed.
Has been like that for almost 1 week now.
Running Kodi 16.1 on Ubuntu 16.04
OMDB api
Change Log
01/12/17
Removed single character restriction from title/search results.
(2017-02-11, 02:41)ikaruz Wrote: [ -> ]OMDB api
Change Log
01/12/17
and what must be changed in the addon ?
did you now that also
