2020-02-22, 15:50
2021-03-06, 22:51
(2017-08-29, 01:05)bsoriano Wrote: [ -> ]Hello,Bart:
In case anyone is interested, I have this addon working under Leia in Windows. If you wish to use it for more than keeping Top 250 updated, please remember to include your OMDB API Key as instructed further back in this topic. Unzip the archive in the following link to your addons folder, and remember to enable it in Kodi (Krypton and above):
https://1drv.ms/u/s!AlII29kkG6TFh_R3_Tr_Qd63ObmMJQ
I only use it to update the Top 250 info, so I am not sure it is working fine for other functions.
EDIT: I just tried the ratings and MPAA functions, and they also work well (with the OMDB API Key).
Hope you find it useful.
Regards,
Bart
Are you still using this add-on? If yes, is there a simple way to make it compatible with matrix?
2021-03-07, 00:07
(2021-03-06, 22:51)Edworld Wrote: [ -> ](2017-08-29, 01:05)bsoriano Wrote: [ -> ]Hello,Bart:
Regards,
Bart
@Edworld, I was using it well in Leia. I just switched my main HTPC to Matrix today, and I have not yet looked at how to get it working for Matrix. I will check (to see if it is something I can do with my limited knowledge) in the next few days.
Regards,
Bart
2021-03-07, 17:52
(2021-03-07, 00:07)bsoriano Wrote: [ -> ]How do you get it working in Leia? Your link seems dead.(2021-03-06, 22:51)Edworld Wrote: [ -> ](2017-08-29, 01:05)bsoriano Wrote: [ -> ]Hello,Bart:
Regards,
Bart
Regards,
Bart
