Hey.
I recently installed xbmc 12.2 on my galaxy s4 and whenever I play video files through it, the audio is all crackly and distorted.
I've tried reinstalling and playing around with the audio settings, but to no avail.
Any ideas?
Cheers,
Zander
Here's the log. I hope I did it right. Please let me know if you need me to redo it. I just enabled debugging mode, played a video, then emailed the log.
http://xbmclogs.com/show.php?id=16707
Thanks in advance for any help! :-)
From your log you appear to have a AV-receiver hooked up to your samsung, or do you have another reason for enabling all the passthrough modes ?
Thanks for the reply Kibje!
I'm not sure. that's literally after a fresh install :S.
What should i turn off?
Just check all your audio settings. You most likely only have stereo audio on that phone, so do not select any 'capable receiver' options.
This should not be selected by default.
Where did you download the android version of XBMC ?
Try the following:
Audio output: Analog
Speaker configuration: 2.0
Audio output device: android - audiotrack
(according to log only 1 device present so chose from)
Please I'm having the same issue ... installed the latest version of XBMC 12.2 from
http://xbmc.org/download/ on to my new S4 (I9500)
When ever I open a video (online or on my system) the audio is crackly and distorted. Tried playing arround with the audio settings ... no luck
While on my iphone 4 every thing is working amazingly ...
Please find me a solution
this is my log:
http://xbmclogs.com/show.php?id=31576 (i cannot open or check it - giving error "502 Bad Gateway")
Please I'm having an issue ... installed the latest version of XBMC 12.2 from
this is my log:
Hi Guys.
I am having the same problem with my S4 (I9500)... Looks like this is an S4 specific issue - multiple people are experiencing this issue on the S4 now.
Please could someone shed some light on to what else we could try to get this working properly.
Have either of you tried the settings I posted?
Change audio settings to 2.0 and Analog. Make sure all "capable receiver" options are unchecked.
Oh, and don't cross-post...
mhd_123 - do not double post your message in several threads.
Merged the 2 threads and moved them to Android support
I'm sorry for my mistake ... jjd-uk I tried your way but no luck ... still same problem
I think it's a problem with the galaxy s4 i9500 ... I tried it on another phone not rooted and on stock rom ... giving same issue
