2014-03-27, 17:47
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
2014-03-27, 22:11
2014-03-28, 01:37
Regss
The application looks awesome. However, I cannot get it working.
This is a new setup with Apache/PHP/Mysql
I set apache to run as myself which gave access rights to /var/www
the directory which the application is in is /var/www/movielib
I ran the installer and that seemed to work
However, I cannot login to the admin page - it simply reloads the login page, if I enter an incorrect password it displays wrong password try again, so that isn't the issue
When looking in phpmyadmin I can see the movielib db has been created and the users have been inserted into the user table
Thoughts?
Update: Resolved that issue
However now I am trying to sync the db. The path to the 'script' is this the path of sync.php or admin.php or something else?
Update: Resolved that issue also
The answer is the path to the sync.php file for others that may also run into the same issue.
Thoughts?
2014-03-28, 02:15
I just wandet to try out your application, but I get errors. It says wrong token. When I checked the log files I find this:
My setup:
XAMPP 1.8.3. (fresh install)
Movielib Service 1.0.1
Movilib Addon 1.2.0
Movielib Script 2.5.0
Windows 7 and 8
XBMC 12.3 Frodo
Any ideas?
00:57:07 T:4408 NOTICE: -->Python Interpreter Initialized<--
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsURL: http://localhost:3306
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsToken: 5qyhsv
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsActors: true
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsPosters: true
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsFanarts: true
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsEpisodes: true
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsISO: false
00:57:07 T:4408 NOTICE: >>>> Movielib <<<< settingsMaster: false
00:57:08 T:4408 NOTICE: >>>> Movielib <<<< http://localhost:3306/sync.php?option=checkversion
00:57:08 T:4408 NOTICE: >>>> Movielib <<<< Check version
00:57:08 T:4408 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xff in position 24: ordinal not in range(128)
File "C:\Users\xxx\AppData\Roaming\XBMC\addons\script.movielib\default.py", line 140, in <module>
Movielib()
File "C:\Users\xxx\AppData\Roaming\XBMC\addons\script.movielib\default.py", line 69, in __init__
self.checkToken()
File "C:\Users\xxx\AppData\Roaming\XBMC\addons\script.movielib\default.py", line 89, in checkToken
self.debug(checkVersion)
File "C:\Users\xxx\AppData\Roaming\XBMC\addons\script.movielib\lib\debug.py", line 19, in debug
xbmc.log('>>>> Movielib <<<< ' + msg.encode('utf-8'))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xff in position 24: ordinal not in range(128)
My setup:
Movilib Addon 1.2.0
Windows 7 and 8
XBMC 12.3 Frodo
Any ideas?
2014-03-28, 13:15
In web browser go to http://localhost:3306/sync.php?option=checkversion and put here result.
2014-03-28, 18:34
When you post the url, I have seen my mistake. The port in the url was wrong.
2014-03-30, 00:46
And again THANX for this great tool.
2014-03-30, 03:49
Hello
just downloaded your latest release (2.5.0)
I switched default view to small poster(2).
If i go to the main site first i get the small poster list. I click on a movie to watch the details.
After that i click 'title' to get the complete list back and now i have the default view big posters (0)
So i need to change the view manually to small poster.
If you click on a sorting button (title,year,rating,added and so on) you should always get the desired view not the default big poster view.
Please can you verify that and maybe fix?
2014-03-30, 11:34
Can you add banner support for tvshows? My banners were resized to posters.
When I change "Panel Top" to "off" I see the place holders in the output ({top_item_last_added} {top_item_most_watched} {top_item_last_played} {top_item_top_rated})
btw great tool
btw great tool
2014-04-05, 20:03
v. 2.5.1
- fixed switching between views
- fixed panel top
- update language
- added support for banners
To update replace all files without install.php.
To get proper banner delete tvshow and sync again.
Thank you all for help.
- fixed panel top
- update language
2014-04-05, 21:09
Very nice! Thanks for the updates will install tomorrow - banner support is interesting! Right now your movielib is the best way to present my movie library
I have a question: In admin panel I can remove tv show/movies by clicking "X" - it works well but I think those removed entries will get added again with the next rescan on xbmc? Is there a way to avoid removed movies/shows to being added by the next rescan?
EDIT: Just unzipped newest master.zip to my webspace but now I get error:
Warning: file_get_contents(templates/default/.tpl) [function.file-get-contents]: failed to open stream: No such file or directory in /users/cocotus/www/movielib/function.php on line 20
2014-04-05, 22:04
Have you logged into admin panel? Usually need to do that too after an update.
2014-04-05, 23:40
(2014-04-05, 22:04)ensignvorik Wrote: [ -> ]Have you logged into admin panel? Usually need to do that too after an update.
thanks for the hint! After I logged into admin panel, site loaded perfectly
2014-04-06, 00:19
Hi, thanx for this addons!
Btw, i've just installed Apache+mysql+php on a RaspberryPi.
i've installed your movielib-master created a mysql user and installed the addons on another computer where there is Xbmc.
all the configuration goes ok..
Now in xbmc log i see:
but it add only a film (without cover) and then i've an error message in xbmc (cant' connect to http://192.168.1.1/)
but in xbmc log seems that a lot of films are added.
Everytime i rerun xbmc only one film and one tvshow are added.... what can i do?
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsURL: http://192.168.1.1
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsToken: *********
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsActors: false
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsPosters: true
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsFanarts: true
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsEpisodes: true
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsISO: false
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< settingsMaster: false
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< http://192.168.1.1/sync.php?option=checkversion
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< Check version
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< 2.5.1
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< Version is valid
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< http://192.168.1.1/sync.php?option=checktoken&token=******
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< Check Token
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< true
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< Valid Token
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< Run Sync Movies
23:50:33 T:1004 NOTICE: >>>> Movielib <<<< movielibMovieID: ['1', '2']
2014-04-07, 00:05
i've removed Apache, installed Nginx... same behavior.
tomorrow i'll try to tune mysql and php on linux... on windows with xampp i've no problem
