2014-05-06, 01:18
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
2014-05-06, 06:56
(2014-05-06, 01:18)Aenima99x Wrote: [ -> ]How often does the addon sync the db? Is it configurable?
Every time you start XBMC, after complete library update and after each stop playback movie or tvshow.
2014-05-08, 15:15
Ok, v. 2.6.0 is out!
v. 2.6.0
- added remote control XBMC
- added support for download video file
- added support for playing video directly
- added filter watched/unwatched
To update replace all files without install.php and go to admin panel.
If you want to use the remote function you must resync all database.
To the remotely options were visible on the page. You must login in to the admin panel and go back to the main page without logging off ("Library" button in admin panel). This is a strange way to show the remote functions is because this functions is a test version.
Configure remote functions:
Enter to admin panel and in sections "XBMC" paste the XBMC host, port, login and pass. Make sure you have enabled server in XBMC.
Test button test connection for you.
v. 2.6.0
2014-05-09, 04:10
2014-05-09, 14:33
"Ok, v. 2.6.0 is out!" -> WOW, many thanks.
2014-05-09, 15:01
Test needed for working remote functions. I noticed that not work on all servers, especially free hostings it have blocked some curl functions.
2014-05-09, 18:50
Running your latest version locally on my lan works perfect so far.
Also the little bug last played is away.
2014-05-10, 04:49
2014-05-10, 18:07
All is working fine with 2.6.0. Great Job.
2014-05-11, 17:01
Another fab update. Won't be using the remote control functions as I use free hosting that is not on my local LAN, and already use my iOS devices as remotes anyway, but nice to have.
Have also donated you a small amount as an appreciation of your work. Thanks
2014-05-21, 13:59
Oh wow that looks sweet - going to update now - Lets see if it working with my freehoster....
2014-05-24, 12:43
hi there when I try to install it on my 000webhost.com I am getting the following error message, any clues why? They use PHP 5.2.17 MySQL version 5.1
There seems to be an error in your SQL query. The MySQL server error output below, if there is any, may also help you in diagnosing the problem
ERROR: Unknown Punctuation String @ 1
STR: <?
SQL: <?PHP
session_start();<?PHP
session_start();
SQL query:
<?PHP session_start();
MySQL said: Documentation
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '<?PHP
session_start()' at line 1
Update:
I have now installed on a ArchLinux machine php, mariadb 5.5.37, apache, I get to the Install page, I put in the details for the mysql and then it changes to http://192.168.0.35/movielib-master/inst...on=success and I cannot do anythig. I already tried to manually create the database which I was able to do with the user xbmc and password xbmc... so I don't know what I am doing wrong here.
STR: <?
SQL: <?PHP
session_start();
SQL query:
Update:
2014-05-24, 23:42
Just look at my brand new signature ! Very cool feature I love it^^
2014-06-05, 18:55
Hi Guys,
can i use this tool for my database stored on my htpc running OpenELEC?
And if yes, how do i do it?
THX for help!
Greets Grobi
THX for help!
Greets Grobi
2014-06-05, 20:27
Yes. I have the add on running on my htpc running openelec 4.0.3 (need to update to 4.0.4)
Just follow the instructions on the 1st page. Obviously you can't use the htpc to host the website interface so you'll need another host for that or some free webspace. I'm using x10.mx
