2014-06-08, 17:32
I seem to be getting errors now. I upgraded to OpenELEC 4.0.4 yesterday (which is XBMC 13.1 final code) so I assume the problem is to do with that?
So not sure currently, if this is something that needs fixing in MovieLib or if I should downgrade back to 4.0.3 (which was on the XBMC 13.1 RC code)
Here's the error:
16:23:02 T:139665508112128 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: No JSON object could be decoded
File "/storage/.xbmc/addons/script.movielib/default.py", line 171, in <module>
Movielib()
File "/storage/.xbmc/addons/script.movielib/default.py", line 70, in __init__
self.checkToken()
File "/storage/.xbmc/addons/script.movielib/default.py", line 111, in checkToken
settings = json.loads(checkSettings)
File "/home/stephan/projects/openelec-4.0/build.OpenELEC-Generic.x86_64-4.0.4/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads
File "/home/stephan/projects/openelec-4.0/build.OpenELEC-Generic.x86_64-4.0.4/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode
File "/home/stephan/projects/openelec-4.0/build.OpenELEC-Generic.x86_64-4.0.4/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
ValueError: No JSON object could be decoded
Here's the error:
Movielib()
self.checkToken()
