2013-06-26, 23:31
I have XBMCbuntu running on 1 PC with XBMC 12.2. Here I enabled the UPNP sharing in the configuration. Now I want to watch videos on another PC with Windows 7. Here is also XBMC 12.2 running. When I add the UPNP share in the videos section everything is OK, I can see the whole list of series and movies. Actually, when I try to watch something, nothing happens and after a while I get an error that it could not play back the video and that I should check the logs...
Here is the part of the logs where it goes wrong (on my client PC (the Windows machine)):
Before I used this same Windows PC to watch videos on another Windows PC (server) and everything went well. So I think I should look for the problem at the server PC (XBMCbuntu).
Could this maybe be a firewall issue? I already check iptables but shows an empty list...
I'm out of options at the moment. Any one another idea? Many thanks!!
23:18:50 T:3508 NOTICE: DVDPlayer: Opening: http://10.0.0.12:62862/%25/460A43D4C539E2A3258F4E0577BD7BA1/S09E02.mkv
23:18:50 T:3508 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
23:18:50 T:6064 NOTICE: Thread CDVDPlayer start, auto delete: false
23:18:50 T:6064 NOTICE: Creating InputStream
23:18:50 T:6064 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
23:18:50 T:6064 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
23:18:50 T:6064 ERROR: XFILE::CFileCache::Open - failed to open source <http://10.0.0.12:62862/%25/460A43D4C539E2A3258F4E0577BD7BA1/S09E02.mkv>
23:18:50 T:6064 ERROR: CDVDPlayer::OpenInputStream - error opening [http://10.0.0.12:62862/%25/460A43D4C539E2A3258F4E0577BD7BA1/S09E02.mkv]
23:18:50 T:6064 NOTICE: CDVDPlayer::OnExit()
23:18:50 T:6064 NOTICE: CDVDPlayer::OnExit() deleting input stream
23:18:50 T:3508 ERROR: Playlist Player: skipping unplayable item: 0, path [upnp://367c5498-825c-e8cd-1cf5-a584a0adf8b2/videodb%3a%2f%2f2%2f2%2f11%2f-2%2f510%3fseason%3d-2%26tvshowid%3d11/]
23:18:50 T:5640 NOTICE: Thread Background Loader start, auto delete: false
23:18:50 T:3508 NOTICE: CDVDPlayer::CloseFile()
23:18:50 T:3508 NOTICE: DVDPlayer: waiting for threads to exit
23:18:50 T:3508 NOTICE: DVDPlayer: finished waiting
