Full Version: Scraping IMDB.com ratings
I've set up EMM v1.3.13 set up to scrape my movies.
Because i like my movie info in "Dutch" i'm using TMDB (because it supports Dutch) as default scraper.
Because i prefere my ratings form IMDB i've set up the Native scraper as second scraper.
Unchecked Ratings and Votes from the TMDB scraper and checked them on de Native Scraper.
For some reason it still grabs the ratings and votes from the TMDB site.
See the images for my settings;
Scrapers - Data:
TMDB Scraper:
Native Scraper:
Hopefully someone can help me out.
Thanks in advance!
Wizzz
I think .13 does not work completely... try the 1.4...
Maybe i'm looking at the wrong place but where to find the 1.4 release?
(2013-06-27, 23:39)m.savazzi Wrote: [ -> ]I think .13 does not work completely... try the 1.4...
Could you please tell me were to find version 1.4?
you need to compile it from GitHub
@Wizzzard
I wanted the same and found this script http://forum.xbmc.org/showthread.php?tid=107331
Worked well for me and you can run it whenever you want
