2013-06-27, 22:19
Is it possible to change any XBMC setting from anywhere in the skin with a SendClick action ?. If so where can i find the ID's for those controls ?.
Example : Let's say that you are in fullscreen video and you want to change the Audio output device.
Adding a button control to the OSD screen like the one bellow it will work ?
Cheers
Nessus
PHP Code:
<onclick>SendClick(SystemSettings, audio-output-device-controlID)</onclick>
Cheers
Nessus
