All the Irish channels are on mpeg4 but the tv is a few years old at this stage and only supports mpeg2. I live on the border and close to 2 transmitters so we can pick up all the channels good on the other tvs. I was going to buy a digital box but then I thought it would be nice to get this working - or i like the look of the PCTV-290e you mentioned. I might buy that but I would like to try the one i got first.
So far all I did was download "dvb-usb-af9015.fw" and paste it into the /lib/firmware folder. Before I did that i was getting an error similar to this (this is not my message i copied it from another forum - i did not note the message before I added the firmware)
[ 8.035155] dvb-usb: did not find the firmware file. (dvb-usb-dib0700-1.20.fw) Please see linux/Documentation/dvb/ for more details on firmware-problems. (-2)
lsusb
Bus 001 Device 004: ID 15a4:9016 Afatech Technologies, Inc. AF9015 DVB-T USB2.0 stick
dmesg | grep 'usb'
[ 0.620797] usbcore: registered new interface driver usbfs
[ 0.620804] usbcore: registered new interface driver hub
[ 0.620824] usbcore: registered new device driver usb
[ 1.424587] usb 1-1: new high speed USB device number 2 using ehci_hcd
[ 1.668532] usb 2-1: new high speed USB device number 2 using ehci_hcd
[ 1.900580] usb 1-1.1: new high speed USB device number 3 using ehci_hcd
[ 2.100547] usb 2-1.4: new full speed USB device number 3 using ehci_hcd
[ 2.272758] usb 1-1.1.2: new high speed USB device number 4 using ehci_hcd
[ 2.408404] input: Afatech DVB-T 2 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/input/input3
[ 2.408462] generic-usb 0003:15A4:9016.0001: input,hidraw0: USB HID v1.01 Keyboard [Afatech DVB-T 2] on usb-0000:00:1a.0-1.1.2/input1
[ 2.408474] usbcore: registered new interface driver usbhid
[ 2.408475] usbhid: USB HID core driver
[ 7.517033] dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in cold state, will try to load a firmware
[ 7.603311] input: Media Center Ed. eHome Infrared Remote Transceiver (045e:006d) as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/rc/rc0/input4
[ 7.603358] rc0: Media Center Ed. eHome Infrared Remote Transceiver (045e:006d) as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/rc/rc0
[ 7.604225] mceusb 2-1.4:1.0: Registered Microsoft Microsoft IR Transceiver on usb2:3
[ 7.604242] usbcore: registered new interface driver mceusb
[ 8.132400] dvb-usb: downloading firmware from file 'dvb-usb-af9015.fw'
[ 8.184617] rc rc0: lirc_dev: driver ir-lirc-codec (mceusb) registered at minor = 0
[ 8.199749] dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in warm state.
[ 8.199814] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 8.560385] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1.2/rc/rc1/input5
[ 8.560441] rc1: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1.2/rc/rc1
[ 8.560443] dvb-usb: schedule remote query interval to 500 msecs.
[ 8.560446] dvb-usb: Afatech AF9015 DVB-T USB2.0 stick successfully initialized and connected.
[ 8.568933] usbcore: registered new interface driver dvb_usb_af9015
I then went into the tvheadend interface and it allowed me to select "Afatech AF9013 DVB-T" (previously it was greyed out). I then selected the nearest mast to me and after the scan it found nothing
So I think the driver must be the wrong type (?)
By the way is that how the driver for the device is installed? Just download a firmware file to that folder?
