2013-09-15, 17:40
2013-09-15, 19:26
(2013-09-13, 18:59)Lupin 3rd Wrote: [ -> ]This preselection window have to appear if the External player code is implemented right
Yes, that selection menu will always appear, even when using an external player.
2013-09-16, 13:33
Try the player uMCEPlayer5.exe in PlayISO.bat file.
I will post my externalplayer code when my htpc is free.
:playiso
"C:\Program Files\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" I:
"C:\Program Files\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
2013-10-07, 14:50
Hello,
I did the trick with playercore xml file as in post 1 for 3d movies with rule for *3DBD* in filename
The problem i have is that powerdvd now is the player for everything, even if the filename doesnt contain 3dbd in it.
What did i do wrong?
Thanx
Thanx
2013-10-07, 17:31
If you have a 3D capable monitor/screen/projector, all you need to do is play the 3D file in xbmc and then hit the 3D button on the monitor/screen/projector's remote and set it to the type of 3d projection that the file is (worked for me using SBS 3D in XBMC on a 3D capable Samsung TV...the xbmc gui and menus are unuseable but you can switch the 3D off to use them)
2014-01-23, 23:42
I've just got XBMC and having exactly the same problem as AngelDust. I have the rule set up for "*3D*" but even if the file is called blah.iso it will still play using the external player. I like the internal player for 2D files so want to keep using that.
2014-04-21, 01:30
I am jumping in this discussion, because I also would like to be able to enjoy playing 3D movies in XBMC.
I have a Computer with NVIDIA graphics board tied to a big 3D screen (HDTMI). I have a collection of movies that includes a considerable amount of 3D movies (.mkv and .avi) I play using powerDVD13.
I have recently loaded my XBMX software, enjoying a lot of things but not 3D movies.
Following what I understood from reading previous messages, I have done the following:
1- Created the file Playercorefactory.xml with the following code =>
<playercorefactory>
<players>
<player name="powerDVD13" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Programas(x86)\cyberlink\powerdvd13\powerdvd13.exe</filename>
<args>"{1}"</args>
<hidexbmc>True</hidexbmc>
<hideconsole>true</hideconsole>
<forceontop>false</forceontop>
</player>
</players>
<rules action="prepend">
<rule filename="*[3D]*" player="powerDVD13"/>
</rules>
</playercorefactory>
2. Have placed the xml file into => C:\Users\jdelara\AppData\Roaming\XBMC\userdata\
3. I have configured the video output in XBMC to use full screen window
All my movies are in separate folders. My collection of 3D movies are under one big folder named 3-D Movies (part of the XBMC library). All my 3D movies name include the wording "[3d]" as part of file-name.
The results:
When a 3D movie is selected, I have in the right click a NEW sub-menu option "PLAY USING.." with 2 choices: "powerDVD13 (default) and "DVDPlayer"
If default selected I have NOTHING!! except that the selected movie is in the now-playing list.
If DVDPlaye is selected, I see double image (left/right or top/down)
It looks like the powerDVD13 is not working.
Any ideas? Any progress on the similar issue described before?
Thanks a lot for your help!
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
</rules>
The results:
2014-04-21, 01:36
What format are your 3d movies in?
2014-04-21, 02:12
(2014-04-21, 01:30)jdelara Wrote: [ -> ]If default selected I have NOTHING!! except that the selected movie is in the now-playing list.If you have not done it, you need to Enable "Use fullscreen window rather than true fullscreen" in XBMC system/settings/system/video output......
2014-04-21, 16:47
Pain in the ass.... External player and 3D
I got it work with .iso and .mkv. but my problem is that all iso and mkv files opens in the external player. I only whant the use the external player for the 3D files.
i had al lot of problems with virtual clone drive, so i use Deamon tools lite for mounting, much better in my eye's
-Windows 8.1
-Powerdvd 13
-Deamon tools lite
-XBMC 12.3 frodo
my playercorefactory file:
<playercorefactory>
<players>
<player name="ISO_BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\dennis\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
</player>
<player name="Disc_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\dennis\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}"</args>
</player>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\CyberLink\PowerDVD13\Movie\PowerDVD Cinema\PowerDVDCinema13.exe</filename>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO/BDMV -->
<rule filetypes="iso|bdmv|mpls" player="ISO_BDMV_Player"/>
<!-- Multiple files -->
<rule filetypes="mkv" filename=".*3D*" player="Universal_Player"/>
<!-- Bluray Disc -->
<rule filetypes="bd|ifo" player="Disc_Player"/>
</rules>
And my PlayISO file:
@echo off
set /A N=0
REM - Load ISO with Deamon tools lite
:playiso
"C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" -mount 0,%1
"C:\Program Files (x86)\CyberLink\PowerDVD13\Movie\PowerDVD Cinema\PowerDVDCinema13.exe" E:\
"C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" -unmount 0
E:\ is my mounting drive letter.
Maby this will help you, i use a diffrent .exe to start powerdvd.
//sorry for bad english
-Windows 8.1
-Powerdvd 13
-Deamon tools lite
-XBMC 12.3 frodo
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
</players>
</rules>
@echo off
set /A N=0
:playiso
2014-04-22, 02:42
The movies' format I use the most is .avi and a few mkv
I just find out that just using the DVDPlayer for 3D movies, gives me a side by side image. Then I can manage to see in 3D using the TV remote.
Basically I put everything back as original.
I am done.
Thanks everybody for your help!!!
I am done.
2014-04-22, 03:41
(2014-04-21, 16:47)xuter010 Wrote: [ -> ]Pain in the ass.... External player and 3DUse the rules below, and name your 3d movie as this (example- SkyFall.3d). Any movie with .3d in it will playback using external player, and all other movies will playback using XBMC internal player....
<rule filetypes="mkv" filename=".*3d." player="Universal_Player"/>
<rule filetypes="iso|bdmv|mpls" filename=".*3d." player="ISO_BDMV_Player"/>
2014-04-22, 03:59
(2014-04-22, 02:42)jdelara Wrote: [ -> ]The movies' format I use the most is .avi and a few mkvYep that's right, Gotham 3d support goes a long way.
I am done.
There are some addons floating around that will send a signal via network to your TV to switch to 3D mode when a 3D movie is played - I have seen one for LG TVs and one for Samsungs.
2014-04-22, 09:02
(2014-04-22, 03:59)nickr Wrote: [ -> ]I 've done it too, with the Gotham 3D support.(2014-04-22, 02:42)jdelara Wrote: [ -> ]The movies' format I use the most is .avi and a few mkvYep that's right, Gotham 3d support goes a long way.
I am done.
Then to see the 3D files in the Library, i asked this here:
http://forum.xbmc.org/showthread.php?tid...pid1599819
Hoping the team adds it to the RC ...
