2013-07-02, 09:09
Guys can anyone give me a hand with this issue I've been having..
I have airplay working streaming to several XBMC media centers running frodo 12.2. The issue am having with with one particular app its called foxtelgo its a streaming cable service. The problem is that xbmc detects the stream being pushed through my ipad but the stream wont load and appears to just crash. Ive tried the stream with an apple tv and it works perfectly.
Can someone have a look at this log and tell me what the issue is and if there is a work around or fix for it.
[/php]
16:16:46 T:3544 DEBUG: ------ Window Init () ------
16:16:54 T:3544 DEBUG: ------ Window Deinit (Pointer.xml) ------
16:16:56 T:3544 DEBUG: ------ Window Init (Pointer.xml) ------
16:16:59 T:3544 DEBUG: Activating window ID: 12006
16:17:00 T:3544 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
16:17:00 T:3544 DEBUG: ------ Window Init (MusicVisualisation.xml) ------
16:17:00 T:4176 DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
16:17:00 T:4176 DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers(pipe://3/)
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
16:17:00 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
16:17:00 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
16:17:00 T:3544 DEBUG: FactoryCodec - Audio: pcm - Opening
16:17:00 T:3544 DEBUG: FactoryCodec - Audio: pcm - Opened
16:17:00 T:5500 DEBUG: AIRPLAY Server: New connection detected
16:17:00 T:5500 INFO: AIRPLAY Server: New connection added
16:17:00 T:5500 DEBUG: AIRPLAY: got request /server-info
16:17:00 T:5500 DEBUG: AIRPLAY: got request /play
16:17:00 T:5500 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/airplay/libplist.dll)
16:17:00 T:5500 DEBUG: AIRPLAY: sending event: loading
16:17:01 T:3544 DEBUG: Previous line repeats 1 times.
16:17:01 T:3544 INFO: AudioDecoder: File is queued
16:17:01 T:3544 INFO: CSoftAE::MakeStream - AE_FMT_S16NE, 44100, FL,FR
16:17:01 T:2180 DEBUG: CSoftAE::Run - Sink was forgotten
16:17:01 T:2180 DEBUG: CSoftAE::Run - Sink restart flagged
16:17:01 T:2180 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
16:17:01 T:2180 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 3081374
16:17:01 T:2180 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
16:17:01 T:2180 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
16:17:01 T:2180 DEBUG: Audio Device : Speakers (High Definition Audio Device)
16:17:01 T:2180 DEBUG: Sample Rate : 44100
16:17:01 T:2180 DEBUG: Sample Format : AE_FMT_FLOAT
16:17:01 T:2180 DEBUG: Bits Per Sample : 32
16:17:01 T:2180 DEBUG: Valid Bits/Samp : 32
16:17:01 T:2180 DEBUG: Channel Count : 2
16:17:01 T:2180 DEBUG: Block Align : 8
16:17:01 T:2180 DEBUG: Avg. Bytes Sec : 352800
16:17:01 T:2180 DEBUG: Samples/Block : 32
16:17:01 T:2180 DEBUG: Format cBSize : 22
16:17:01 T:2180 DEBUG: Channel Layout : FL,FR
16:17:01 T:2180 DEBUG: Channel Mask : 3
16:17:01 T:2180 DEBUG: Frames : 441
16:17:01 T:2180 DEBUG: Frame Samples : 882
16:17:01 T:2180 DEBUG: Frame Size : 8
16:17:01 T:2180 DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
16:17:01 T:2180 DEBUG: Output Device : Speakers - Speakers (High Definition Audio Device)
16:17:01 T:2180 DEBUG: Channel Layout: FL,FR
16:17:01 T:2180 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
16:17:01 T:2180 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
16:17:01 T:2180 DEBUG: AERemap: Downmix normalization is disabled
16:17:01 T:2180 DEBUG: CSoftAEStream::CSoftAEStream - Converting from AE_FMT_S16NE to AE_FMT_FLOAT
16:17:01 T:3544 DEBUG: AudioDecoder::GetReplayGain - Final Replaygain applied: 1.000000, Track/Album Gain 89.000000, Peak 0.000000
16:17:01 T:2180 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
16:17:02 T:3544 INFO: PAPlayer::PrepareStream - Ready
16:17:02 T:3544 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
16:17:02 T:3000 NOTICE: Thread PAPlayer start, auto delete: false
16:17:02 T:3000 DEBUG: PAPlayer::Process - Playback started
16:17:02 T:3544 DEBUG: ------ Window Deinit (MusicVisualisation.xml) ------
16:17:02 T:3544 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
16:17:02 T:3544 DEBUG: ------ Window Init (SettingsCategory.xml) ------
16:17:02 T:3544 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
16:17:02 T:3544 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
16:17:02 T:3544 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://192.168.1.103
16:17:02 T:2180 DEBUG: CSoftAE::Run - Sink restart flagged
16:17:02 T:2180 DEBUG: CAESinkDirectSound::IsCompatible: Formats compatible - reusing existing sink
16:17:02 T:2180 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 44100hz
16:17:02 T:2180 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
16:17:02 T:2180 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
16:17:05 T:3000 INFO: PAPlayer::ProcessStream - Stream Finished
16:17:05 T:3000 DEBUG: CSoftAEStream::~CSoftAEStream - Destructed
16:17:05 T:3000 DEBUG: PAPlayer::ProcessStreams - Stream Freed
16:17:05 T:2180 DEBUG: CSoftAE::Run - Sink restart flagged
16:17:05 T:2180 DEBUG: CAESinkDirectSound::IsCompatible: Formats compatible - reusing existing sink
16:17:05 T:2180 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 44100hz
16:17:05 T:2180 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
16:17:05 T:2180 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
16:17:07 T:3544 DEBUG: CCurlFile::GetMimeType - http://192.168.1.103:52868/server/tokeniser/3/206/542985.m3u8?format=WIFIHIGHLIVE&__gda__=1372747638_ebb64d67fe158e8523e97f2716fec786|User-Agent=AppleCoreMedia%2f1.0.0.8F455%20(AppleTV%3b%20U%3b%20CPU%20OS%204_3%20like%20Mac%20OS%20X%3b%20de_de) -> failed
16:17:07 T:3544 DEBUG: DialogProgress::StartModal called
16:17:07 T:3544 DEBUG: ------ Window Init (DialogProgress.xml) ------
16:17:07 T:3544 DEBUG: CGUIInfoManager::SetCurrentSong(pipe://3/)
16:17:07 T:3544 DEBUG: CFileItem::LoadMusicTag: loading tag information for file: pipe://3/
16:17:07 T:3544 DEBUG: Loading additional tag info for file pipe://3/
16:17:07 T:3544 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
16:17:07 T:3544 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
16:17:07 T:3544 DEBUG: AIRPLAY: sending event: playing
16:17:07 T:3544 DEBUG: Previous line repeats 1 times.
16:17:07 T:3000 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
16:17:07 T:3000 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
16:17:07 T:3000 DEBUG: AIRPLAY: sending event: stopped
16:17:07 T:3000 DEBUG: Previous line repeats 1 times.
16:17:07 T:3000 DEBUG: Thread PAPlayer 3000 terminating
16:17:07 T:3544 DEBUG: ------ Window Deinit (Pointer.xml) ------
16:17:07 T:5656 NOTICE: Thread CGUIDialogCache start, auto delete: true
16:17:07 T:5656 DEBUG: Thread CGUIDialogCache 5656 terminating (autodelete)
16:17:07 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers(http://192.168.1.103:52868/server/tokeniser/3/206/542985.m3u8?format=WIFIHIGHLIVE&__gda__=1372747638_ebb64d67fe158e8523e97f2716fec786|User-Agent=AppleCoreMedia%2f1.0.0.8F455%20(AppleTV%3b%20U%3b%20CPU%20OS%204_3%20like%20Mac%20OS%20X%3b%20de_de))
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: streams
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: aacp/sdp
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mp2
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
16:17:07 T:3544 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
16:17:07 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
16:17:07 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
16:17:07 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
16:17:07 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
16:17:07 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
16:17:07 T:3544 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
16:17:07 T:3544 NOTICE: DVDPlayer: Opening: http://192.168.1.103:52868/server/tokeniser/3/206/542985.m3u8?format=WIFIHIGHLIVE&__gda__=1372747638_ebb64d67fe158e8523e97f2716fec786|User-Agent=AppleCoreMedia%2f1.0.0.8F455%20(AppleTV%3b%20U%3b%20CPU%20OS%204_3%20like%20Mac%20OS%20X%3b%20de_de)
16:17:07 T:3544 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
16:17:07 T:3544 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
16:17:07 T:3544 DEBUG: DXVA - cheking samples array size using 842094158 render target
16:17:07 T:3544 DEBUG: DXVA - cheking samples array size using 842094169 render target
16:17:07 T:6040 NOTICE: Thread CDVDPlayer start, auto delete: false
16:17:07 T:6040 NOTICE: Creating InputStream
16:17:07 T:6040 DEBUG: CFileCache::Open - opening <server/tokeniser/3/206/542985.m3u8> using cache
16:17:07 T:6040 DEBUG: CurlFile::Open(093C5C10) http://192.168.1.103:52868/server/tokeniser/3/206/542985.m3u8?format=WIFIHIGHLIVE&__gda__=1372747638_ebb64d67fe158e8523e97f2716fec786
16:17:07 T:3544 DEBUG: ------ Window Init (DialogBusy.xml) ------
16:17:07 T:3544 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
16:17:08 T:1296 NOTICE: Thread CFileCache start, auto delete: false
16:17:08 T:1296 INFO: CFileCache::Process - Hit eof.
16:17:08 T:6040 INFO: Auto-selecting http://fxmultihlslive6258.ngcdn.telstra.com/channel002/channel002600.m3u8?SIGV=2&IS=0&ET=1372756231&KO=7&KN=2&US=b31503e8d1bd40371cf29bc9e780539132f64a6b based on configured bandwidth.
16:17:08 T:1296 DEBUG: Thread CFileCache 1296 terminating
16:17:08 T:6040 NOTICE: Creating Demuxer
16:17:08 T:6040 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
16:17:08 T:6040 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcodec-53.dll)
16:17:08 T:6040 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avformat-53.dll)
16:17:08 T:6040 DEBUG: ffmpeg[1798]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
16:17:08 T:6040 DEBUG: Previous line repeats 2 times.
16:17:08 T:6040 ERROR: ffmpeg[1798]: Unable to open key file https://foxtel-go-sw.foxtelplayer.foxtel.com.au/server/keyserver/?siteID=206&videoID=542985&profile=tablet&system=rpgr2&subsystem=channel002&key=K5509540600.key
16:17:09 T:6040 DEBUG: Previous line repeats 5 times.
16:17:09 T:6040 DEBUG: Error, could not open file http://fxmultihlslive6258.ngcdn.telstra.com/channel002/channel002600.m3u8?SIGV=2&IS=0&ET=1372756231&KO=7&KN=2&US=b31503e8d1bd40371cf29bc9e780539132f64a6b
16:17:09 T:6040 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
16:17:09 T:6040 NOTICE: CDVDPlayer::OnExit()
16:17:09 T:6040 NOTICE: CDVDPlayer::OnExit() deleting input stream
16:17:09 T:6040 DEBUG: Thread CDVDPlayer 6040 terminating
16:17:09 T:3544 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
16:17:09 T:3544 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
16:17:09 T:3544 NOTICE: CDVDPlayer::CloseFile()
16:17:09 T:3544 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
16:17:09 T:3544 NOTICE: DVDPlayer: waiting for threads to exit
16:17:09 T:3544 NOTICE: DVDPlayer: finished waiting
16:17:09 T:5500 DEBUG: AIRPLAY: got request /rate with rate 1
16:17:09 T:5500 DEBUG: AIRPLAY: got request /playback-info
16:17:09 T:5500 INFO: AIRPLAY Server: Disconnection detected
16:17:09 T:3544 INFO: Previous line repeats 1 times.
16:17:09 T:3544 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
16:17:09 T:5500 DEBUG: AIRPLAY Server: New connection detected
16:17:09 T:5500 INFO: AIRPLAY Server: New connection added
16:17:09 T:5500 DEBUG: AIRPLAY: got request /server-info
16:17:09 T:5500 DEBUG: AIRPLAY: got request /stop
16:17:09 T:5548 INFO: Previous line repeats 1 times.
16:17:09 T:5548 DEBUG: Thread Jobworker 5548 terminating (autodelete)
16:17:11 T:3544 DEBUG: ------ Window Init (Pointer.xml) ------
16:17:15 T:2180 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
16:17:15 T:2180 DEBUG: Suspended the Sink
16:17:18 T:3544 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
16:17:18 T:3544 NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:17:18 T:3544 NOTICE: Log level changed to 0
