2013-07-02, 16:02
Hey guys,
I made a fresh install of xbmcbuntu 12.2 and upgraded the kernel to 3.10. Everything looks good but I am having trouble getting the sound to output correctly to my logitech z5500. I noted my previous settings which worked great in 12.1 but I am getting nothing with them.
I went into alsamixer and S/PDIF, S/PDIF Default PCM, S/PDIF 1, S/PDIF 2 are all enabled but S/PDIF 16 is muted. When I unmuted this the sound worked perfectly but when I play a movie I get a loud static sound for a second at the start. Would anyone have an idea what I can do to sort this?
My audio settings are:
Audio output : Optical/Coax
Speaker : 5.1
boost volume level on downmix : [enabled]
output stereo : [not enabled]
ac3 : [enabled]
dts : [enabled]
aac : [not enabled]
Audio output device : HDA Intel PCH, ALC887-VD Digital S/PDIF : [enabled]
Passthrough output device : HDA Intel PCH, ALC887-VD Digital S/PDIF : [enabled]
thanks very much
Speaker : 5.1
ac3 : [enabled]
dts : [enabled]
aac : [not enabled]
thanks very much
