Full Version: Re-installing XBMC
I am having issues with the YouTube plugin (it doesn't work for me - script failed).
Hence, most of the plugins I want to use don't work as they use Youtube. (xbmchub)
I am running Frodo 12.2 and Youtube 4.4.4
How do I re-install XBMC without loosing all my plugins, settings, etc?
thanks
Have you already checked out or asked in the YouTube add-on thread (especially the last few pages)?
http://forum.xbmc.org/showthread.php?tid=79487
You should also examine your debug log (wiki) to see why the script is failing.
I couldn't see anything in the YouTube thread but I will check the log file and post.
thanks
Ok, here is my log file for Youtube and 1Channel not working
http://xbmclogs.com/show.php?id=34128
And crash file log
http://xbmclogs.com/show.php?id=34129
Have you installed the common plugin cache add on?
http://wiki.xbmc.org/index.php?title=Add...ugin_cache
From the errors I saw in the log I think that could be it.
I do have that one installed, I didn't have Simple Downloader for xbmc plugins, so that fixed Youtube.
But 1Channel is not working or Easynews, filmon
http://xbmclogs.com/show.php?id=34130
No support for 1Channel or other piracy Add-ons here.
