2014-07-12, 01:41
heres the error log
[Thu Jul 10 16:24:00.269000 2014] [ssl:warn] [pid 1572:tid 256] AH01909: RSA certificate configured for www.example.com:443 does NOT include an ID which matches the server name
[Thu Jul 10 16:24:00.551000 2014] [ssl:warn] [pid 1572:tid 256] AH01909: RSA certificate configured for www.example.com:443 does NOT include an ID which matches the server name
[Thu Jul 10 16:24:00.587000 2014] [mpm_winnt:notice] [pid 1572:tid 256] AH00455: Apache/2.4.7 (Win32) OpenSSL/1.0.1e PHP/5.5.9 configured -- resuming normal operations
[Thu Jul 10 16:24:00.587000 2014] [mpm_winnt:notice] [pid 1572:tid 256] AH00456: Apache Lounge VC11 Server built: Nov 21 2013 20:13:01
[Thu Jul 10 16:24:00.588000 2014] [core:notice] [pid 1572:tid 256] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Thu Jul 10 16:24:00.590000 2014] [mpm_winnt:notice] [pid 1572:tid 256] AH00418: Parent: Created child process 4528
[Thu Jul 10 16:24:01.270000 2014] [ssl:warn] [pid 4528:tid 268] AH01909: RSA certificate configured for www.example.com:443 does NOT include an ID which matches the server name
[Thu Jul 10 16:24:01.529000 2014] [ssl:warn] [pid 4528:tid 268] AH01909: RSA certificate configured for www.example.com:443 does NOT include an ID which matches the server name
[Thu Jul 10 16:24:01.577000 2014] [mpm_winnt:notice] [pid 4528:tid 268] AH00354: Child: Starting 150 worker threads.
[Thu Jul 10 19:19:05.777000 2014] [mpm_winnt:warn] [pid 4528:tid 1728] (OS 121)The semaphore timeout period has expired. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Thu Jul 10 19:19:05.778000 2014] [mpm_winnt:warn] [pid 4528:tid 1728] (OS 64)The specified network name is no longer available. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Thu Jul 10 22:22:30.109000 2014] [mpm_winnt:warn] [pid 4528:tid 1728] (OS 64)The specified network name is no longer available. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Fri Jul 11 06:32:47.674000 2014] [mpm_winnt:warn] [pid 4528:tid 1728] (OS 64)The specified network name is no longer available. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Fri Jul 11 07:20:17.454000 2014] [mpm_winnt:warn] [pid 4528:tid 1728] (OS 64)The specified network name is no longer available. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
